brighter lights : Yamaha R1 Forum
SportbikeTrackGear
Old 11-24-2012, 11:38 AM   #1
Josestrainz
Josestrainz's Avatar
Bikes: 2006 R1
brighter lights
i have an 06 r1, i have stock head lights and want to make them brighter. can i get bulbs with more "candle power" without haveing to go with hid's?
Josestrainz is offline   Reply With Quote
Old 11-24-2012, 11:48 AM   #2
Minacious
Death's Handshake
Minacious's Avatar
Bikes: They're just bikes, you've seen 'em.
Why don't you want to go HID? These projectors were made for them.
You're pretty limited, as far as lumen range is concerned, with standard halogen bulbs. Some go with higher wattage bulbs than what is rated for the stock wires, but that can lead to issues. It also doesn't really increase light output to any great degree over the standard wattage.
HIDs are relatively cheap, and depending on the brand, stupidly cheap. The DDM range falls under stupidly cheap, and many have run them for years without a hitch. You can also choose to pay a little more for parts with a bit better construction, but still fall under what I would consider cheap, especially considering the amount of light they throw out. If you frequently ride at night, they should be a must.
The installation of them takes about 15-20 minutes, maybe more for a first-timer deciding on where to place the wiring and ballasts.
Ed - Klingon women are HOT! (A Trekker for life)
CG Artist and Sci-Fi Nerd
Manic-Depressive and my head hurts.
Minacious is offline   Reply With Quote
Old 11-24-2012, 11:51 AM   #3
shaftman_05
shaftman_05's Avatar
Bikes: 05 R1 shift red!
What this guy said! ^
shaftman_05 is offline   Reply With Quote
Old 11-24-2012, 11:53 AM   #4
shaftman_05
I have four HID's on my 05. 6K for lows and 5K on my highs. I did a bit more work and installed halos as well. You can try some Sylvania silver stars. But they really don't put out more lumens. It's only a trick of the eye.
Old 11-24-2012, 12:25 PM   #5
Josestrainz
Bikes: 2006 R1
I have stock highs and my low hid's went out. I slapped stock bulbs while my new hid's arrive but i wasnt happy or comfortable at all with the lighting before. can I run all 4 as low and high beam? I like the halos and am planning on ordering some this winter.
Old 11-24-2012, 01:07 PM   #6
shaftman_05
No you can not effectively run them all four as lows or all four as highs. The housing is not designed for it. You will be blinding to oncoming traffic. It will be like highs all the time. Also it will equal being pulled over for brighting people FTL...
Old 11-24-2012, 01:08 PM   #7
shaftman_05
All HID's is your only true brighter fix.
Old 11-24-2012, 01:22 PM   #8
Josestrainz
Bikes: 2006 R1
Cool, thanks. Halos and hide it is.
Old 11-24-2012, 01:33 PM   #9
smalltrack
big tracks scare me
smalltrack's Avatar
Bikes: R6 track slut
Aggracing.com for HID's.
smalltrack is offline   Reply With Quote
Old 11-24-2012, 02:12 PM   #10
shaftman_05
DDMTUNING treated me nice. Takes a lil longer to receive the package but I have had no problems with mine. I ran 35W. If our want 55W you will need to upgrade the wiring...
Old 11-24-2012, 04:54 PM   #11
kingnba6
R1der
kingnba6's Avatar
Bikes: 2006 R1 Blue
im running 55w 6k lows from ddm tuning and some 3k yellow halogen high beams. i hardly use my highbeams since the hids because of the great light output.
My 06 R1 Build Thread
R1-013 'Lucky 13th' Squadron
kingnba6 is offline   Reply With Quote
Old 11-24-2012, 05:02 PM   #12
mr2guru
U win some U lose some
mr2guru's Avatar
Bikes: 2009 VMAX, 2006 R1 50thAE
I have DDM tuning 6000k 35w lows and 4300k 55w high beams...
Highs are insane.
mr2guru is offline   Reply With Quote
Old 11-24-2012, 05:17 PM   #13
MMMichael
I've got a little side question on this subject.. Not to hijack..
But when ordering, what's the difference between single beam and bixenon? Just curious..
Also where did you guys mount the ballasts?
Okay.. Hijack over. Thanks!
MMMichael is offline   Reply With Quote
Old 11-24-2012, 05:22 PM   #14
z064life
R1 Forum Star
z064life's Avatar
between the headlights or on the side fairings
Hey Greenstreak, it's Z064life lazy ass
Old 11-24-2012, 05:28 PM   #15
smalltrack
big tracks scare me
smalltrack's Avatar
Single beam means the low beam and high beam are separate (if that's how your car/bike work) and bixenon is having a hi and lo in one bulb.
Old 11-24-2012, 06:51 PM   #16
poizen bananaz
That's it
Bikes: 05 R1
Gonna get some soon thanks to you guys.
poizen bananaz is offline   Reply With Quote
Old 11-24-2012, 08:30 PM   #17
kingnba6
R1der
kingnba6's Avatar
Bikes: 2006 R1 Blue
for the 04-08 r1s you need single beam h7 for low beams and if you want high beams too you will need to buy another pair of single beam h7.
on the new r1s 09+ you only need to buy a single beam h7 since the projector of the new r1s does both high and low thru a "cover"
Old 11-25-2012, 08:21 AM   #18
poizen bananaz
That's it
Bikes: 05 R1
Thanks for the info. Wondering if I should go 5k, 6k, etc. for lows/ highs. I know it affects the color but anyone have their opinions? Thanks
Old 11-25-2012, 08:30 AM   #19
kingnba6
R1der
kingnba6's Avatar
Bikes: 2006 R1 Blue
if you want the whitest light get 5k. if you want some blue color get 6k
http://www.r1-forum.com/forums/showt...&highlight=hid
Old 11-25-2012, 11:01 AM   #20
Minacious
Death's Handshake
Minacious's Avatar
To expand on the above reply, color temp and luminosity play off of one another. Your color temp (kelvins) with dictate both the color of the light being thrown as well as how bright (lumens) the light bring thrown is.
The brightest you can get will be from the 4100-4300k range and have a yellowish/white color. Going up from there, the light goes from white (5000k), to blue (6000k-8000K), to purple (10000k-12000). On the flip side, as you go down the range (3000k and below), the light turn very yellow.
As you go higher in the kelvin range, you lose light output in place of color. The same for lower. Again, the 4000k range being optimal. This is where you decide on light output versus performance. The most popular range is probably the 5000k to 6000k range; a white light or white with a touch of blue in it.
I'm a performance whore and through the years have run 55w kits with 4000k to 5000k range bulbs. To call them a night sun would be an understatement.
