» Site Navigation |
» Motorcycle Forums
| Technique & Riding Want to kneescrape? Go faster in corners? Smoother riding? Anything about how to ride goes in here please. |
11-25-2012, 09:56 AM
#1
Timekeeper
Bikes: R1
Clipons resisting countersteer
Sold my 10' back in Apr and bought a dl650 but just picked up an 09' not to long ago. Question is with the 09 I feel a fair amount of resistance and even some push back while cornering. I don't ever remember cornering feeling like that on my 10'. In fact I remember it being effortless and intuitive. Anyone think this is indicative of a problem on the 09 I bought or is it all just in my head?
11-25-2012, 09:59 AM
#2
I RACE U LOSE
Checked front tire pressure ? Rear axle aligned ?
'06 50th GYT-R CarbonSlipons,Akra Y Graves stacks,blockoffs,covers BMCair Bazzaz Zafm Zfi mapsw Vortex w/520ERV3 Shogun sliders Vortex rearsets Renthal med.comp Ballistic12cell Stompgrip CRG levers Galfer SBK fr&rr rotors ProboltTi  '12 50th WGP#145. Graves full Ti carbon ex,stacks,blockoffs BMCair Yosh case,oilfill,yokenut,axleblocks Renthal w/520ERV3 CRG RC2's Watsen's Shogun framesliders Renthal med.comp Ballistic8cell ProboltTi  Lucky 13th R1-013Squadron Member
11-25-2012, 10:07 AM
#3
Timekeeper
Bikes: R1
Tire pressure is 32 front 36 rear cold. Everything looks straight. But I'll double check on the axle.
11-25-2012, 10:58 AM
#4
Bikes: 2011 Raven R1
Make sure the rear is still a 190/55 not a 50. It's likely in your suspension setup if everything else is ok. Tune it a bit yourself, or find a shop locally to assist..does wonders.
11-25-2012, 12:01 PM
#5
R1 Forum Star
cornering either way have issues or is one more than the other? Could check to make sure your front wheel is aligned (when the clipons are square to the frame, the wheel should be straight.
Does it have aftermarket clipons? Did you '10? Are they turned in a lot?
Originally Posted by Gearheaded
Originally Posted by MelvinAkshay
PJ, so you lied to me.  lol it doesn't look that big
11-25-2012, 01:23 PM
#6
Booya
Bikes: 1943 Indian Scout 741
You adjusted your rear and front suspension yet? Set the bike up for your weight?
"Universe is 14 billion years old. Seems silly to celebrate one year. Be like having a fvcking parade every time I take a piss." -- ShitMyDadSays
Originally Posted by Fikays
Yeah it was head trauma alright....but it was my little head that was traumatized by your mouth.
11-25-2012, 02:25 PM
#7
ROWDY
Bikes: 2009 Yamaha R1
Sounds normal to me! The 09 seems to stand up, and require input through the turn.
ROWDY
11-25-2012, 02:31 PM
#8
Bikes: 2007 R1
Sounds like a difference in body positioning (weight distribution really) and or suspension settings between the two bikes. Not sure if the suspension is the same between the two bikes, but have you checked that the settings are the same?
11-26-2012, 02:58 AM
#9
Timekeeper
Bikes: R1
Yea I still have to setup the suspension to my weight on this bike. I rode the 10' without messing with the suspension for about a month when I first bought it and never noticed this. But maybe I just forgot about it. It honestly feels like a severly underinflated front tire but I checked the pressure with 3 different gauges and they all showed 32.
No after market clipons and eveything looks straight and lined up and i feel equal pressure turning left or right. Maybe I just need to ride it more. Coming from the upright dl650 and being used to how that bike behaves while cornering might be messing with my brain.
11-26-2012, 05:20 AM
#10
The Lead Farmer
You should start by setting up the suspension here.
http://www.r1-forum.com/forums/showthread.php?t=252234
If you're really light, you will have to pull out some preload to get it to turn better. Most of the stock bikes take a little tweaking to get them to handle better mid turn. I think the 09 and 10 had springs set up for an 160# rider.
Necessity is the plea for every infringement of every human freedom, It is the argument of tyrants; It is the creed of slaves.
William Pitt 1783
Phantom Squadron #37
12-04-2012, 02:10 AM
#11
2005 Yamaha R1
Bikes: 2005 R1
Could be worn tires. Run your hand over the tires (across them) and see if there is high spot in the middle. If so, that could be what is causing the pushing back you feel in the clipons.
Ray
12-04-2012, 04:12 AM
#12
R1 Forum Star
Ray
explain this?? I've turned tires into having angled sides and a the top (nearly a triangle if you took a cross section (2" flat/rounded on top) and have never had the resistance in turning. What is this "high spot" you are looking for and how would one have that??
12-04-2012, 01:01 PM
#13
2005 Yamaha R1
Bikes: 2005 R1
I had a similar situation as the original poster and couldn't figure it out - feeling as though there was a pushing back resistance via the clip-ons during cornering. I went by two local race shots and both said it was probably tires. One place, the guy ran his hand over the tires and said "probably your tires". When I got home, I did the same thing and noticed there was a high spot in the middle of the tire (at least on the front), sort of like a hump. In the rear, there was a flat area in the middle (was running a 190/55 in the rear).
As soon as I put on new tires, the bike went back to having that smooth intuitive steering feel and the "fighting the steering" sensation went away. This is why I was asking how many miles on the tires, etc. Naturally, I could be wrong, but I think it's always a good idea to check both tire pressure and tire condition. In 5 years of owning my R1, I've had 3 very strange issues on the bike and in each case, it was tracked down to the tires:
1. A strange harmonic vibration coming through the clip-ons at 55 MPH. Traced to unbalanced/worn tires.
2. A strange feeling of the bike not tracking properly via corners. I had allowed my tire pressures to drop to ~15 PSI front and 18 rear without realizing it.
3. A strange pushing back feeling in the clip-ons. Traced to worn tires front/rear.
It's worth a check.
Ray
12-04-2012, 01:28 PM
#14
Noodles, don't noodles...
Bikes: 06 R1 50th, 09 R1 Blue, 03 Graves R6
This is a used bike, more than likely, so the previous owner may have played with the suspension settings. It may also need a refresh considering the age. I agree with Meister, set the suspension up and you'll likely get rid of that feeling.
In a game of losers, there are no winners.
 Thanks Petrol!
Thanks to: WWW.SuperbikeSupply.com
Originally Posted by KMac
I'm speechless.
12-08-2012, 03:18 AM
#15
Timekeeper
Bikes: R1
UPDATE:
Setup the suspension to my weight and took it out for a few corners near my house, still had the same clipon pushback issue coupled with some weird wallowing or bouncing while pushing the bike a little harder through the corners.
Then I remembered what the tire pressures were when the seller swung by my house for me to check it out. Somewhere in high teens/ low 20's which may have deformed the tires??? Took RayJohns on his experience and bought a new pair of Q2's and threw them on. Bingo! Cornering how I remember it. Thank you to all who chimed in on my issue.
12-08-2012, 11:44 PM
#16
Frosty runs are the best
Bikes: Want a new bike
Change your wheel bearings while your at it also.
12-09-2012, 03:57 AM
#17
2005 Yamaha R1
Bikes: 2005 R1
UPDATE:
That's great - congrats on resolving the handling issue! :-)
BTW, be super careful on new Q2's. I put a set on my R1 and promptly low sided last month; wrecked my bike and nearly killed myself (came off an apex at 70 MPH and stuck the bike and myself into a concrete rain gutter and dirt embankment).
New Q2's are great, but they are slippery on the sides when new. Make sure you are running a pressure on the lowerside for the street, so they heat up.
Ride safe!
Ray
12-19-2012, 12:34 PM
#18
So...
It was hopelessly low tyre pressures all along then?
Actually, it was the the low tyre presssure's allowing an unusual contact patch and thus irregular changes in dynamic trail values. That and the increse in slip angle forces significantly overcoming the self aligning torque inherent in the steering.
Tyre pressures; I shittem.
And whilst I'm
Dunlop Q2's work just fine. More or less any tyre will have you off if you forget to scrub them in... its not Dunlop that's at fault here.
Have a nice day.
Grumpy Andy
12-23-2012, 10:10 AM
#19
I 100% disagree about the q2's. I put brand new q2's on ealier this year (peeled stckers off and out i went) and first lap out ran the piss out of them at the track with no issues (note, no warmers). As long as the bike is set up correctly, you're not going to overuse q2's on the street. Very aggressive right out of the gate and I'm by no means professional.
Poor throttle control, rider mistake, or poor road conditions make people go down on the street. Poor road condition is usually last in the street crash issues.
No offense to anyone, but as others have said, you can't blame equipment.
Moral of the story, take the aggressive riding to the track
12-23-2012, 10:20 AM
#20
2005 Yamaha R1
Bikes: 2005 R1
Most people I know who race say the Q2's are slick when cold/new. Of course, that's true of most any tire probably also.
I'm going to keep the Q2's and maybe run them on the track. For the street, I'm installing Pirelli Supercorsa SP's and going to give those a try. I think the SP's are probably better tires than the Q2. The Q2's are good tires for the money for sure, but I don't think they are in the same ball park as the higher end Pirellis.
Time will tell.
The 190/55 Q2's are 200mm wide, while the Supercorsa Sp's are more like 188 as I recall (I think they are 193 on the rims, but I'll double check when I mount them).
In my specific crash, it was because the tires were not fully scrubbed in, it was cold and I had the pressure too high probably (35/35 when I probably should have been running more like 30/30 maybe for the temp).
The main issue is a dip in the road at the apex. I'm not the first person who has had problems on this particular corner. However, I had come around that same corner many times on the Corsa III's and stepped out the back end with no problem.
You say you put Q2's on and had no problem first lap. But I know someone who did that and low sided on the first corner also...
Talk to 10 people, you'll get 10 different opinions.
Q2's are a lot of bang for the buck. Myself, personally, I like the feedback from the Pirelli tires a bit more I think. I might try the Q2's at a lower PSI and see how they do, but replacing body work ain't cheap :-)
Ray
| Sponsored Links |
| Thread Tools |
| Display Modes |
Linear Mode
