» Site Navigation |
» Motorcycle Forums
11-29-2012, 03:12 PM
#1
Bikes: 2012 R1 Black Dragon
front Sprocket installation
Hi Guys,
How easy is it to install a front sprocket to '12. I'm thinking of order the 16T from OEM 2003 model.
links to guide or instructions would be great.
11-29-2012, 03:43 PM
#2
R1 Forum Star
if it's never been off, its got an unreal amount of locktite on it.
Bend tabs out (2 sides, screwdriver will bend them)....then use an impact wrench to remove the nut...Don't use an impact to put it back on though
Originally Posted by Gearheaded
Originally Posted by MelvinAkshay
PJ, so you lied to me.  lol it doesn't look that big
11-29-2012, 03:48 PM
#3
so not a 10min job, need heavy duty air powered wrench?
11-29-2012, 03:52 PM
#4
R1 Forum Star
10 min job if you have an air wrench...if you dont' you are going to need to rig up something to keep the sprocket from spinning...even in gear it will turn under the force it will take to take the nut off.
#5
Recreational adrenaline user
Bikes: 2008 Raven R1
That's what I used and it came off quick. I had trouble with it using hand tools and I've heard others have too.
I used a piece of rebar wrapped in a towel through the spokes to hold the rear wheel in place (pretty ghetto) but still couldn't bust the thing loose with my longest breaker bar. I finally hauled out the compressor and air tools and it came off instantly.
"MeanOne": 2008 Raven R1
11-29-2012, 03:56 PM
#6
Dang! thanks for your replay mate!
#7
R1 Forum Star
Give you a good excuse to buy some tools...I can't tell you how much my collection has grown since buying a bike
11-29-2012, 05:03 PM
#8
I RACE U LOSE
My '12 has a notch in the shaft that the outer edge of nut gets peened into, has no lock plate with tabs. Nut was easy to remove with 1/2 inch breaker bar, bike in gear with foot on rear brake. Torque nut to 66 ft.lbs.
'06 50th GYT-R CarbonSlipons,Akra Y Graves stacks,blockoffs,covers BMCair Bazzaz Zafm Zfi mapsw Vortex w/520ERV3 Shogun sliders Vortex rearsets Renthal med.comp Ballistic12cell Stompgrip CRG levers Galfer SBK fr&rr rotors ProboltTi  '12 50th WGP#145. Graves full Ti carbon ex,stacks,blockoffs BMCair Yosh case,oilfill,yokenut,axleblocks Renthal w/520ERV3 CRG RC2's Watsen's Shogun framesliders Renthal med.comp Ballistic8cell ProboltTi  Lucky 13th R1-013Squadron Member
11-29-2012, 05:19 PM
#9
para bellum
air wrench is for wimps...
Brothers riding on...
Bandrews 10/11
Dieyoung69 11/10
Vman1300 3/09
Gawarrior 6/08
Elviswarrior 6/07
Crazyclimbr 3/07
K_flexxx 6/06
11-29-2012, 05:36 PM
#10
Frnds dn't let frnds apx early
Bikes: Less than I want
I use my teeth.
Sig courtesy of my brotha from down unda PetrolSpice
11-29-2012, 05:43 PM
#11
R1 Forum Star
that's what I meant by using the screwdriver...if I remember anyway
rear brake on is a good idea...honestly didn't think of that
11-29-2012, 06:52 PM
#12
LIVE EVERY MOMENT!
Bikes: 2010 r1
air impact gun..not in gear...rear brake worked for me on my first bike. was soaked in wd for a few days.
11-29-2012, 07:43 PM
#13
MummyMan
Bikes: 1999 r1, 07 GSXR 1k
Originally Posted by WestSide_'10R1
air impact gun.. not in gear...rear brake worked for me on my first bike. was soaked in wd for a few days.
Very important part in bold. Don't have it in gear or you risk tranny damage. Best is to use the rear brake as other said. It's a pretty easy job overall.
11-30-2012, 02:41 AM
#14
another way would be to use a long blacker bar, jackup the real wheel, place the socket on the nut, the handle of the bar against the ground, start the bike, put in gear and give it a bit of gas... can you see where im going with this.
This is how we remove a crank pully from a car when there is no air tools.
11-30-2012, 03:20 AM
#15
I never knew having it in gear could cause tranny problems... Yikes!
Good to know!!  :
Sent from my ADR6425LVW using Motorcycle.com Free App
| Sponsored Links |
| Thread Tools |
| Display Modes |
Linear Mode
