Need Help with bike overheating ASAP : Yamaha R1 Forum
SportbikeTrackGear
Old 12-03-2012, 05:04 AM   #1
Medevack1
Never forget!!!
Medevack1's Avatar
Bikes: '06 R1 50th anniversary & 99 YZF R1
Hey guys I need your help I’m stuck at work with a broke bike. First off I have a 1999 R1, the bike has been running fine until last night. It was about 45 degrees and on my way home (75mph) I can see the temp gauge jumping from 168 to 200 back to 180 then spiking to 230, the temp light came on once, I can hear the fan working so I know it’s not the fan. the temp stayed at 199 the entire way home (10 miles). This morning I checked the coolant bottle and it was to the full line so I rode the bike to work. When I got off the exit I saw the temp gauge and it was 189 when I pulled into work it was 235 and the light was back on the fan was running. So I parked it and took a closer look the radiator cap was not hot, the hoses were hot and I saw a drop of coolant coming from the left upper hose, it was tight. So anyone can help!!!! I sure appreciate it.
http://i.imgur.com/1pGDiYj.png
"The Lord knows the way I take, and when He has tested me, I shall come forth as gold" JOB 23:10
"Nightstalkers for life" Never Leave a Soldier Behind
Medevack1 is offline   Reply With Quote
Old 12-03-2012, 05:19 AM   #2
T.C.
Bourbon is my blood
T.C.'s Avatar
Has the coolant level dropped at all in the radiator?
If the level has dropped a bit, an air pocket can form and the temp sender could be getting a false reading.
Sig by Uncle P.
T.C. is offline   Reply With Quote
Old 12-03-2012, 05:46 AM   #3
Medevack1
Never forget!!!
Medevack1's Avatar
No the level still good.
Old 12-03-2012, 05:57 AM   #4
T.C.
Bourbon is my blood
T.C.'s Avatar
Sounds like you may have a blockage in the radiator.
Hopefully someone else will chime in with some ideas for you.
Sorry I couldn't help any more than that. Good luck.
Sig by Uncle P.
Old 12-03-2012, 06:13 AM   #5
Medevack1
Never forget!!!
Medevack1's Avatar
Thank you i really appreciate it!!!!
Old 12-03-2012, 06:49 AM   #6
Medevack1
Never forget!!!
Medevack1's Avatar
Someone told me it might be the thermostat?
Old 12-03-2012, 07:13 AM   #7
FOGOAR1
Friggin Old Guy On An R1
FOGOAR1's Avatar
Bikes: 04 R1
I can't think of any mechanical condition/reason that would cause sparatic temp swings as you describe. I tend to believe that it is an electrical issue with either the temp sending unit or wiring associated with
FOGOAR1 is online now   Reply With Quote
Old 12-03-2012, 07:54 AM   #8
Medevack1
Never forget!!!
Medevack1's Avatar
what about the drop of coolant that was coming out of the upper hose would that be because of pressure overheating?
Old 12-03-2012, 08:38 AM   #9
z064life
R1 Forum Star
z064life's Avatar
did you check the level in the radiator or in the reservoir??
Old 12-03-2012, 08:55 AM   #10
masenomics
Bikes: 07 R1, 12 yz450f
you need a thermostat
masenomics is offline   Reply With Quote
Old 12-03-2012, 11:59 AM   #11
Medevack1
Never forget!!!
Medevack1's Avatar
ok can i run it w/o a thermostat for now?
Old 12-03-2012, 05:10 PM   #12
Medevack1
Never forget!!!
Medevack1's Avatar
Ok On my way home the temp stayed at 199, once i got home and took the plastic off, i inspect the bike and found a split on the upper radiator hose. Time to replace the thermostat, hose, and do a complete flush!!!!!
Old 12-04-2012, 05:46 AM   #13
Medevack1
Never forget!!!
Medevack1's Avatar
Does anyone have the OEM part # for the 1999 R1 thermostat?
Old 12-04-2012, 05:52 AM   #14
FOGOAR1
FOGOAR1's Avatar
Bikes: 04 R1
http://www.yamahapartshouse.com/oemp.../radiator-hose
Old 12-04-2012, 06:30 AM   #15
Medevack1
Never forget!!!
Medevack1's Avatar
Originally Posted by FOGOAR1 View Post
Awesome thank you im saving that link im my favs.
Old 12-04-2012, 07:04 AM   #16
Medevack1
Never forget!!!
Medevack1's Avatar
Hey thank you for the info, i found a thermostat at a local Parts store 7.99 instead of the stealership 40.00
http://shop.advanceautoparts.com/web...%2C#fragment-1
Old 12-05-2012, 08:16 PM   #17
Sharksawyer
Is there anybody out there?
Bikes: 99 R1
While you're messing with your cooling system, it might be a good idea to replace your thermo switch with one manufactured by Wells. Part number SW518 available at Autozone. Will switch the fan on at about 180 degrees instead of 220. Installed one on mine a few years ago and it works great!
Mark
99 R1
