» Site Navigation |
» Motorcycle Forums
12-06-2012, 03:02 AM
#1
Bikes: 2006 R1
engine died after hitting bump
Got a 06 R1. I was riding my bike as I ran over a hole in the road. It hit pretty hard suddenly the bike instantly started misfiring and died. I'm stranded on side of the road. Does anyone have any suggest5ions. Its
grees and I'm freezing. Help!!!!!
12-06-2012, 03:26 AM
#2
Bikes: 2006 R1
The bike turns over but it wont start. Injectors prime but nothing. Its like its not getting spark. Help
12-06-2012, 03:36 AM
#3
Bourbon is my blood
First check the switch on your side stand. A wire might have come off.
I'd be checking all the connectors you can, and the fuses.
Maybe a wire popped off you coils.
Check your leads to the spark plugs.
Make sure everything is tight on the battery terminals.
Hopefully someone else will chime in with more tips.
Good luck mate.
12-06-2012, 04:01 AM
#4
It's just like a video game.
Bikes: 2011 R1
Because of the sudden jolt it may have thought you was involved in an accident and activated the sensor to shut the engine down. Not sure how to reset it though.
12-06-2012, 05:10 AM
#5
[ Premium Member ]
Bikes: 07
I had the same problem once, after the bike went for a nap on its side.
If this is the same as my scenario, then it may well be the tilt sensor. Go into DIAG mode and toggle the engine on/off switch. Then switch off the ignition and retry to start the bike up.
Keep it real...
______________________________________________
12-06-2012, 09:03 AM
#6
Bikes: 00 R1
Maybe the OP froze
Bogie is the man, and I should learn not to mess with him
12-06-2012, 09:53 AM
#7
SuperModerateur
Bikes: 1980 Huffy Santa Fe
Avoid bumps and holes in the road.
12-06-2012, 10:28 AM
#8
Bikes: 2008 R1
 Great advice. Now all he needs is a flux capacitor so he can go back in time and miss that pot hole!
12-06-2012, 10:38 AM
#9
Frnds dn't let frnds apx early
Bikes: Less than I want
I would check the coils. Make sure they are all the way snapped down on the plug.
Sig courtesy of my brotha from down unda PetrolSpice
12-06-2012, 10:51 AM
#10
R1, "A Superior Addiction"
Bikes: 06 R1
That's what it sounds like to me or the main harness is not making proper contact.
Lucky 13 Squadron
12-06-2012, 10:55 AM
#11
para bellum
check the kill switch?
Brothers riding on...
Bandrews 10/11
Dieyoung69 11/10
Vman1300 3/09
Gawarrior 6/08
Elviswarrior 6/07
Crazyclimbr 3/07
K_flexxx 6/06
12-06-2012, 10:57 AM
#12
Bikes: 2008 R1
The bike wouldn't turn at all with the Kill switch on, would it?
12-06-2012, 11:04 AM
#13
para bellum
it'll still prime the injectors and do the tach sweep
Bandrews 10/11
Dieyoung69 11/10
Vman1300 3/09
Gawarrior 6/08
Elviswarrior 6/07
Crazyclimbr 3/07
K_flexxx 6/06
12-06-2012, 11:08 AM
#14
Bikes: 2008 R1
Right, but he made it sound like it was (turning over) but not starting. Or maybe I'm just tired or dumb and have no clue what's going on!
12-06-2012, 11:18 AM
#15
para bellum
If you hit the kill switch while the bike is still rolling, it'll try to start and sound like misfiring. I don't know if the 2nd post was at a standstill.  :
Bandrews 10/11
Dieyoung69 11/10
Vman1300 3/09
Gawarrior 6/08
Elviswarrior 6/07
Crazyclimbr 3/07
K_flexxx 6/06
12-06-2012, 11:31 AM
#16
Bikes: 2006 R1
Ok guys lets try this again. it was very foggy, it was a man hole cover that dropped about 2 inches lowerthan the pavement. i ran over it at about 40 but the bikes suspension really bottomed out really hard. instantly the bike was like running on 2 cylinders misfiring and backfiring for about 2 blocks the second i pulled over and pulled the clutch it died and didnt start again. needless to say AAA sucked ass they took 5.5 hours to pickme up and flatbed the bike home. how do i reset the tilt sensor? idk whatelse to check. i know now how to go in DIAG mode. then what? what am i looking for? alll the codes have numbers but 2 of them. #20, and#21, the both say ON. WHAT DOES THAT MEAN? What ami missing????
12-06-2012, 11:34 AM
#17
Bikes: 2006 R1
the bike is home ive gone thru everything i think. i tried to start it but it won't. itll turn over but its not firing up.
#18
para bellum
http://www.r1-forum.com/forums/showt...722&highlight=
should have done this on day 1 of your bike ownership.
Bandrews 10/11
Dieyoung69 11/10
Vman1300 3/09
Gawarrior 6/08
Elviswarrior 6/07
Crazyclimbr 3/07
K_flexxx 6/06
12-06-2012, 08:47 PM
#19
loud pipes save lives
Bikes: 2009 R1
To start with you can disconnect the battery for a hard reset. Give it 10min and try starting it. Find what the codes mean and go to those sensors and check their connections. During the impact a sensor might have disconnected or got broken.
12-06-2012, 10:36 PM
#20
R1 or nothin
Bikes: R1 2009, YZF Thundercat 2000, RZ350 YPVS, Honda NS400R
Best thing is to download the workshop manual, then you have a detailed view of all error codes and also how to reset the tip sensor...good luck!
Bones heal and chicks dig scars!!!
| Sponsored Links |
| Thread Tools |
| Display Modes |
Linear Mode
