» Site Navigation |
» Motorcycle Forums
12-06-2012, 05:40 AM
#1
2009 R1
Bikes: 2009 Yamaha R1 Raven
Tune then flash or Flash then tune?
Just wonder what order I should follow. I have the PC5 with Autotune. Should I get the bike dyno tuned THEN get the ECU flashed? Or flash it THEN get it tuned? Thanks!
2009 R1 Raven
Yoshi R77 CF Dual cans w/y-pipe
PowerCommander V
AutoTune
Graves Block Offs
Watsen Flushmounts
luck
12-06-2012, 05:54 AM
#2
nOOb
Bikes: 2011 R1
Flash first to get rid of the restrictions...
LRRS AM
RSP Racing #920
Sponsors: Pirelli, Tony's trackdays, Motorcycle Tires and Gear, Dyno Solutions, Sportbike Track Gear, Knox, Woodcraft, 434racer.com
12-06-2012, 05:55 AM
#3
2009 R1
Ok sweet. Should I go with Flash tune or ECUnleashed?
2009 R1 Raven
PowerCommander V
AutoTune
Graves Block Offs
Watsen Flushmounts
luck
12-06-2012, 06:24 AM
#4
Bikes: 2011 Raven R1
The flash-tune interface is the way to go. You can do everything youself and make infinite changes. Def flash, then tune as he said.
12-06-2012, 06:25 AM
#5
R1 Forum Star
yep..and if you are using a dyno to tune, with the interface you technically don't need the PCV.
Originally Posted by Gearheaded
Originally Posted by MelvinAkshay
PJ, so you lied to me.  lol it doesn't look that big
12-06-2012, 06:27 AM
#6
True, but that'd be a painstaking and time consuming way to tune (remove ecu, make adjustments, 5 min flash time, reinstall, repeat). I'd hang onto the PCV for now.
12-06-2012, 06:34 AM
#7
2009 R1
Ok sounds good. Ordering the interface today! I won't need the auto tune anymore correct? Or would it be a good idea to keep it?
2009 R1 Raven
PowerCommander V
AutoTune
Graves Block Offs
Watsen Flushmounts
luck
12-06-2012, 06:36 AM
#8
R1 Forum Star
You don't need it...what are you doing with it. I ride at many tracks in many different conditions so I like the autotune to use it the 1st couple sessions of the weekend. If you are a street rider, I'd save your money.
12-06-2012, 06:37 AM
#9
LOL. "Yeah, ditch it, matter of fact I'll handle that for you". Really, he's right though. If you're getting a custom tune, you shouldn't ever need it again unless you drastically change altitude or something like that.
12-06-2012, 06:41 AM
#10
2009 R1
Thanks for all the input guys. Guess gonna get this ECU flashed, sell this auto tune, and take the bike in to get all tuned up.
2009 R1 Raven
PowerCommander V
AutoTune
Graves Block Offs
Watsen Flushmounts
luck
12-06-2012, 07:38 AM
#11
Take the red pill
Bikes: '09 R1
Why not keep the autotune and skip the dyno tuning session? Put in 13.0 on the autotune and you should be done.
12-06-2012, 07:41 AM
#12
2009 R1
Bc as I understand it no auto tune is as good as a real dyno tune done by someone who knows what there doing. Unless I have been misinformed?
2009 R1 Raven
PowerCommander V
AutoTune
Graves Block Offs
Watsen Flushmounts
luck
12-06-2012, 07:45 AM
#13
nOOb
Bikes: 2011 R1
If your tuner is cool like mine, get the flash, put the PCV on, get the custom tune, take the PCV off, then get it flashed again and import your map...no piggybacks to fail.
LRRS AM
RSP Racing #920
12-06-2012, 07:48 AM
#14
nOOb
Bikes: 2011 R1
The autotune is NOT as good as a custom tune...A custom tune is to get the best a/f ratios/performance out of YOUR bike...every machine is different. Plus, the auto tune is only good up to 6k rpms. Set it up with a custom tune and never look back (unless you go from sea level to Colorado lol). the only reason to keep the auto tune is for gas milage where you are under the 6k (like highway). But I don't think you bought it for the gas mileage.
LRRS AM
RSP Racing #920
#15
2009 R1
Now that's a great idea!
2009 R1 Raven
PowerCommander V
AutoTune
Graves Block Offs
Watsen Flushmounts
luck
#16
Dan Kyle, a good tuner, says the AutoTune will get you very close if you have an idea of what your optimum AFR is. On an autotune, you're able to make changes under real riding conditions including ram air, etc. With the dyno, you're dealing with an expert (hopefully) who will smooth everything out and should be able to make a nice curve for you. Some tuners are better than others, if you have an awesome tuner, the custom tune might be better. But I run an auto tune and have no plans of getting rid of it.
12-06-2012, 07:52 AM
#17
nOOb
Bikes: 2011 R1
Here's my plan:
Flash to de-restrict, turn off AIS (use plates too), Turn off O2 sensor, use the speedo healer function (-1 in the front), change fan setting.
Put on PCV
Custom tune
Take off PCV
Re-flash importing my custom map
Never look back
LRRS AM
RSP Racing #920
12-06-2012, 07:53 AM
#18
R1 Forum Star
why does an autotune only work under 6k?
A dyno tune is better and the only way to figure out optimum AFRs as AKDMA stated...after that autotune is more accurate
12-06-2012, 07:56 AM
#19
nOOb
Bikes: 2011 R1
Auto tune, from what was explained to me, reads the gas/o2 level in exhaust through the o2 sensor. At the 6k point, the o2 sensor no longer becomes useful and the ECU reads from the map that is on it. I may be wrong, but that is the way it was explained to me.
LRRS AM
RSP Racing #920
12-06-2012, 07:57 AM
#20
R1 Forum Star
You are wrong. An autotune read all the way to the engine's limit.
| Sponsored Links |
| Thread Tools |
| Display Modes |
Linear Mode
