Should I remove my EXUP valve on my 2006 R1? : Yamaha R1 Forum
Graves Motorsports
Old 12-07-2012, 02:37 PM   #1
2qk4u
2qk4u's Avatar
Just liking for pros and cons about removing my exup valve. What do you all recommend? If it doesn't give you anymore performance then is it worth really removing? I do not want to lose any lower end or power in general. I don't really care about losing 1 pound if that's the main reason people remove. I do have a graves plug to prevent light coming on. Opinions are appreciated. Thanks
2006 Yamaha R1 Raven, DB Windscreen, Russell Steel Braided brake lines, Frame Sliders, Flush Markers, A&R Track Baffle kit and PC stock cans, PC3, PC Rear sets, Solo Seat, Pazzo Levers
2qk4u is offline   Reply With Quote
Old 12-07-2012, 02:48 PM   #2
It depends on what else you have done or plan to do with it. Just removing the exup will mess up your fuelling. You'll need a Powercommander (or similar) and a remap, to gain any benefits.
When my 06 was mostly stock, all in one go I gutted the cat, removed the exup, fitted GYTR slip ons, Factory Pro velocity stacks, a Powercommander, and had it dyno tuned. That made a massive difference to the weak standard midrange, it revved up more quickly and made more power up top. But the biggest gains were in the midrange, right where you use it most on the road.
Old 12-07-2012, 03:28 PM   #3
Redgecko
buckfarack fan club
Redgecko's Avatar
Bikes: 06 R1
And to give you another opinion.....
No leave it where it is.
Redgecko is offline   Reply With Quote
Old 12-07-2012, 03:49 PM   #4
2qk4u
2qk4u's Avatar
I do have a pc3 and car is gutted and smog block offs. I plan on doing the velocity stacks and getting a custom tune. Just looking to see if its worth taking off from people who have actually done it and seen results or not. Anymore honest opinions is much appreciated fellas. Thanks
Old 12-07-2012, 03:55 PM   #5
jcobb78
My R1 loves me.
jcobb78's Avatar
Bikes: 2004 R1 (blue)
I did the EXUP delete myself, even removed the flapper valve in the header. Im also running A&R baffles, and a gutted Y pipe. Its breathes like a FULL system now for a fraction of the cost of an Akrapovic, for example....... I obviously had her dynotuned with the power commander due to these changes and let me tell you, she is a beast! She "only" made 150 horses at the rear wheel. lol I know some guys talk of bigger numbers in the 150's but im pretty happy with 150 and my set up. instead of really coming alive at 9K rpm's, its more like 7K and the front wheel is coming UP quick.
i say delete it all as long as you have a PC3 or 5 to get it tuned for your air/fuel ratios.
2004 R1
-PCV
-Smog block off plates
-Shorty levers
-Rear seat cowl
-Graves mirror block-offs
-CRG Arrow bar-end mirror
-Puig smoke windscreen
-Evotech Gas Cap
-Skur CF triple tree cover and guage cover
-Lacomoto carbon fiber swingarm cover
More mods to come....
jcobb78 is offline   Reply With Quote
Old 01-27-2013, 07:17 PM   #6
dimitrios
dimitrios's Avatar
Bikes: 2005 R1 Raven
jcobb, would be interesting to do what you did. since I'm replacing my cylinder head, had to take off the headers, noticed the two metal cables to the exup where actually broken! So, i would like to just remove this exup valve and just cover the hole. But I don't have a power commander. is that really needed, is the bike gonna give shit without it?
Also, what is the flapper valve in the header? Did you buy the plug (exup eliminator)?
2005 Yamaha YZF-R1 Black Raven
Check my blog http://yamaha-r1-diy.blogspot.com/
dimitrios is offline   Reply With Quote
Old 01-28-2013, 05:55 AM   #7
kingnba6
R1der
kingnba6's Avatar
Bikes: 2006 R1 Blue
what i did, i cut the valve connected to the exup (the valve is the flapper inside the headers) so the outside of the exup looks the same but the inside doesnt have the flapper/valve anymore. i bought and installed a dynojet exup delete. and a tune with power commander is very much needed to actually make the bike feel alive!
My 06 R1 Build Thread
R1-013 'Lucky 13th' Squadron
kingnba6 is offline   Reply With Quote
Old 01-31-2013, 06:06 AM   #8
jilbake
Well unless you have a tune on a Dyno and have it jetted properly and what not, You will lose some lower and throttle response and torque On quick acceleration. Something that you could almost described as a flat spot. The design of the exhaust Being so big in diameter is to give the bike flow at high RPMs to produce more upper end torque and horsepower, While the Exup system was implemented to allow for those increases at higher rpm's and still get the bike the back pressure needed for low-end throttle response.
jilbake is offline   Reply With Quote
Old 01-31-2013, 06:13 AM   #9
jilbake
Try not to pay much attention to the grammar. I'm using speech to text and it can be a pain in the ass :0.
