Stalling : Yamaha R1 Forum
Old 12-09-2012, 02:13 AM   #1
Gsalleh
Gsalleh's Avatar
Stalling
My 09 R1 can only go 232 km/h @10500 rpm. When i pull the throttle more, its on and off. Any idea with the trouble? Help me guys. Thanks.
Gsalleh is offline   Reply With Quote
Old 12-09-2012, 04:41 AM   #2
z064life
R1 Forum Star
z064life's Avatar
PRM enabled???
sounds like you are hitting your rev limiter. Have you flashed your ECU
Old 12-09-2012, 05:08 AM   #3
Gsalleh
Gsalleh's Avatar
Ecu still stock. It impossible rev limiter at 10500 rpm. Rev cut should be at 13500 rpm. I'd recently change the spark plugs at 20000 km. Any more idea?
Old 12-09-2012, 08:10 AM   #4
quick kurt
I RACE U LOSE
quick kurt's Avatar
Will it rev out normally in the lower gears? I'm guessing its not getting enough fuel, do you have an aftermarket gascap? Make sure vent hoses near kickstand aren't pinched off, if you don't have an nonstock gascap and the vent hoses are o.k., fuel feed hoses are prone to kinking after removing the fueltank for servicing. Search "no kink fuelhose" here on the forum, do a run through the gears revving each one out and see what happens. Fuelpump could be going bad, but do the no kink fuel hose mod first even if it looks o.k.,to eliminate that scenario. Good Luck !
'06 50th GYT-R CarbonSlipons,Akra Y Graves stacks,blockoffs,covers BMCair Bazzaz Zafm Zfi mapsw Vortex w/520ERV3 Shogun sliders Vortex rearsets Renthal med.comp Ballistic12cell Stompgrip CRG levers Galfer SBK fr&rr rotors ProboltTi'12 50th WGP#145. Graves full Ti carbon ex,stacks,blockoffs BMCair Yosh case,oilfill,yokenut,axleblocks Renthal w/520ERV3 CRG RC2's Watsen's Shogun framesliders Renthal med.comp Ballistic8cell ProboltTi Lucky 13th R1-013Squadron Member
quick kurt is offline   Reply With Quote
Old 12-09-2012, 08:11 AM   #5
z064life
R1 Forum Star
z064life's Avatar
Yep...fuel would be my next guess if it is a stock ecu
Old 12-09-2012, 08:13 AM   #6
quick kurt
I RACE U LOSE
quick kurt's Avatar
Power Commanders go bad occasionally as well, if you have one.
Old 12-09-2012, 03:12 PM   #7
Gsalleh
Gsalleh's Avatar
Yup gascap aren't stock. Will check the fuel hose. Thanks guys. I'll come back to you if its other hehe
Old 12-14-2012, 11:40 PM   #8
Racer Dude
Racer Dude's Avatar
Bikes: 00 R1
PRM enabled???
Bogie is the man, and I should learn not to mess with him
Racer Dude is online now   Reply With Quote
Old 12-16-2012, 03:40 PM   #9
quick kurt
I RACE U LOSE
quick kurt's Avatar
Any luck yet ?
Old 12-31-2012, 07:04 AM   #10
Gsalleh
Gsalleh's Avatar
You absolutely correct mate. The fuel hose kinked. Now it goes back to 299 kmh. Thanks for the help.
Old 12-31-2012, 07:56 AM   #11
quick kurt
I RACE U LOSE
quick kurt's Avatar
Good to hear,always feels good to help someone out.
