Carbon Fiber Look Clutch and Brake Lever Review... : Yamaha R1 Forum
Appearance Windshields / Body Work / Turn Signals / Fender Eliminators, Sticker sets etc etc
Old 05-08-2003, 01:06 PM   #1
R1Fanatic
THEY CALLED ME SWEETNESS!!!!!!
R1Fanatic's Avatar
Bikes: 2004 R1
I recently purchased the LP carbon fiber look clutch and brake lever set. These levers look really good, however, I found a flaw in the brake lever yesterday. The spring in it appears to kinda weak, and when you pull in the brake lever, it doesn't return to the original position, therefore, the brake light remains on until you manually push the brake lever forward.
It may not be a big deal to some people, but it irritated the hell out of me when I noticed it last night.
Has anyone else with similar levers noticed this problem, or did I get a bad lever?
R1Fanatic is offline   Reply With Quote
Old 05-14-2003, 12:34 PM   #2
digdis
Bikes: 2K2 Liq. Sil.
ihad the same problem. The hole in the clutch lever was drilled at an angle and wouldn't fit right either. I had to really mess with it to get it to work. As for the break lever - I glued a little piece (1/8 " thick) of metal to the portion of the lever that pushes the stoplight relay on and off. Works fine now.
digdis is offline   Reply With Quote
Old 05-14-2003, 04:18 PM   #3
AaronR1
Bikes: 2002 Yamaha R1
i just noticed mine doing that last night also. at first i thought it had something to do with my taillight kit but then after playing around a little bit i figured it out. i'm not sure what brand they are but i ordered them from mccoy motorsports, i have yet to try and devise a way to take care of the problem.
AaronR1 is offline   Reply With Quote
Old 05-29-2003, 12:42 AM   #4
VinR1
VinR1's Avatar
Bikes: 95 YSR50, '99 R6, '01 R6, '02 748, '00 996, '99 R1, ' 01 R1, '04 R1, '06 coming soon?
no offense, but did you grease the bearings? I installed the same levers less than a week ago and had the same problems with both. took them off and put a generous amount of grease on the screws that hold the levers - work great now... also, both nuts are locking and dont need to be torqued. it is possible to over tighten them and bind the levers slightly
VinR1 is offline   Reply With Quote
Yamaha Motorcycles Victory Gunner Forum Honda Vultus Forum HD LiveWire Forum Ninja H2 Forum Ducati Scrambler Forum Kawasaki Ninja 250SL Forum
