'03 rear shock rebuild? : Yamaha R1 Forum
Graves MotorsportsMotorcycle.com Classifieds!Motorcycle.comSportbikeTrackGear
Old 05-29-2003, 01:35 AM   #1
Mr Evil
Just let me think about that !
Mr Evil's Avatar
Bikes: 2001 R1
I've got a 2003 model rear shock on my '01. I called a local suspension workshop and inquired about getting the shock rebuilt. They told me they'd fit new spring, screwed preload adjuster, new compression valving, new rebound valving and the associated checking and fitting,gassing.
The price is much less than buying an ohlins. The workshop claims they have used the modded oem shock on race bikes and works very well.
Does anyone have an opinion of rebuilding the oem shock?
Billet top clamp-custom billet damper mount-full Ti muzzy-jet kit-airbox mod-AFE filter-flow commander-ported-R1 carbon grips-carbon tach face-custom billet bar ends-gilles rearsets-custom paint-flushmounts-anodized disk centers-all suspension re-valved & resprung-rear suspension link-tinted screen-seat cowl-afam 47 rear-180/55 rear-chrome levers-chrome top/bottom clamps-braided brake lines-heat wrapped headers-xenon globes-tank bra-did I miss anything?
Mr Evil is offline   Reply With Quote
Old 09-06-2003, 07:44 PM   #2
CZ Eddie
CZ Eddie's Avatar
Bikes: '99 Red R1
How hard was it to get the '03 shock on your '01?
And any news of the possible rebuild?
CZ Eddie is offline   Reply With Quote
Old 09-06-2003, 09:49 PM   #3
Mr Evil
Mr Evil's Avatar
Bikes: 2001 R1
How hard.
Dead set easy.
Remove lower fairings, support back of bike at frame just behind engine sump. Remove 14mm bolts which bolt shock in and drop it out the bottom.
Very, very easy. The '03 shock fits straight in, no modification neccessary.
Since this post I have had the '03 shock in my '01 completely rebuilt (resprung, screwed preload adjuster, new valve, valving setup by the guy which goes the factory yamaha team suspension, modified reservior and 5mm shorted lower linkage). I am extremely happy with the result and it cost heaps less than an ohlins or penske, and furthermore this shock is now setup exactly to MY weight which is better than an off the shelf ohlins.
Old 10-06-2003, 11:26 PM   #4
CZ Eddie
CZ Eddie's Avatar
Bikes: '99 Red R1
lol, just did a search to find out about this swap and found this. guess I forgot about my question.
thanks for answering.
ps. have you tried 03 forks yet?
Old 10-07-2003, 01:35 AM   #5
Mr Evil
Mr Evil's Avatar
Bikes: 2001 R1
Had the forks rebuilt by the same guy that did my rear. I wanted the same guy to do the front. He knows what valving is in the rear so he could balance the bike correctly.
He fitted new compression and rebound valves, springs, 5wt oil and checked over all other componenets. This guy is used by the factory yamaha team here in Australia so he knows his stuff.
Price was very reasonable and I'm very happy with the bike.
All my suspension works has completely transformed my bike. Im faster and it feels much more stable, doesnt nose dive under brakes and soaks up bumps much better.
