» Site Navigation |
» Motorcycle Forums
06-03-2003, 11:50 AM
#1
My R1 eats out women
Bikes: 2002 R1, 02 R6
Ohlins internals 2002 r1
I recently installed Ohlins internals kit in the front forks of an 02 r1. How is it supposed to feel.
It feels wrong. I opened them back up 3 times and all parts are in correctly. To me it feels like no rebound, none at all. Like, when the bike goes over a speed bump, it goes thwack on the way up when it tops out. (with max rebound set.)
2002 RED R1
attack rearsets, vortex clipons, sliders, michelin slicks, sprocket Specialist 520 conversion, DID Erv2 chain, NRC engine covers, harris grips, brembo master, hotbodies fairings, graves stacks, graves stay, ss lines, ebc HH kit pads, pcIIIR, Ohlins shock, ohlins internals, race tech springs, APE Adjustable cam gears, yec racing head gasket, angle milled head, high velocity port job - HOLY F*&%NG SH*T this thing is nucking futs!!!!! Attack gp shift kit, mps quick shifter, Toby Damper, Full Race Hindle High Exit!!!!. oh yah, and an r6 on the side.
06-04-2003, 01:36 AM
#2
Bikes: 00 R1, ZXR750L1
correct amount of oil in? definatly got all the air out of the forks? Ohlins should give a bigger range and bouncing the forks at standstill you should be able to feel the difference in rebound settings. Sounds like there is no oil in there!!
Rehab is for quitters
06-04-2003, 06:47 PM
#3
yep
500ml in each one. so they are full. But I couldn't get the cartritges to fill up. They had an air gap inside. Does the tool that you pump the cartridges with - does it hold down the compression rod allowing better oil flow for charging?
2002 RED R1
| Sponsored Links |
| Thread Tools |
| Display Modes |
Linear Mode
