steering head bearing replacement? : Yamaha R1 Forum
Graves Motorsports
Old 06-07-2003, 05:43 AM   #1
adamgeek
adamgeek's Avatar
Bikes: I've had too many to list, haha.
anyone done this before?
as you may know.. bike went down a few weeks ago, hit a pole at low speed, dented one of the forks. i replaced the forks but kept the stock steering head. then it started to click a bit on braking..
looked like the lower stem nut (under the tripple clamp) was loose.. so i got in there w/ a hammer and screwdriver and snugged it up. started clicking again today, i snugged it some more.. didn't fix it.. and now it's making even worse noises when not braking (i.e. if i yank on the bars hard back and forth, etc). So i am gonna swpa in the spare steering head i got w/ my forks. anything to look out for? any of the bearings need to be pressed in?
i am just hoping it's nearly the same job as swapping the forks. i.e. take off the nose and wheel, headlight, forks + steering head. swap forks into new head.. put back into bike. reassemble.
sound ok? thx in advance.
adamgeek is offline   Reply With Quote
Old 06-07-2003, 05:53 AM   #2
NHSPIKE
STORK MODE = stealthy torque
NHSPIKE's Avatar
Bikes: R1
Adamgeek,
When I bought my R-1 from a wheelie-happy type owner, I tightened, and tightened, and tightened until it finally stopped clicking.
I took it all apart, there seemed to be no damage to the race, or the balls, so I put it back together and tried the tighter is better technique... always checking (with the front end up in the air) for any binding.
It's been 10 months or more since I've had any kind of clicking, and it's smooth as silk.
Perhaps you haven't tightened it enuff?
May save some time/effort/$ to try one more time before a major rebuild...
dunno fur sure though
spikey
NHSPIKE is offline   Reply With Quote
Old 06-09-2003, 07:59 PM   #3
integrars
Bikes: Yamaha R1
they make a tappered version of that bearing specifically for the R1 I ordered it the other day will give my 2 cents after it is installed should last longer.
integrars is offline   Reply With Quote
Old 06-09-2003, 08:01 PM   #4
02RedR1
Young and Stupid
02RedR1's Avatar
Bikes: some say too many, i say too few
man, mine has clicked for the longest time...what to tighten????
R1-Forum.com "O.G." AKA: Matt-tastic
www.TurfWorksOK.com
02RedR1 is offline   Reply With Quote
Old 06-09-2003, 08:06 PM   #5
martinc
martinc's Avatar
Bikes: 99 R1/07 1098S TRE
Nah,the needle-type tapper bearings are crap......stick with the ball-bearings.
Remove the crappy rubber washer and throw it as far as you can...hello fewer adjustments intervals.
I bet if we could find a star-shaped lock washer to put between the top triple and the top nut,added to the removal of the rubber washer,we wouldnt have to adjust them that often.
Its all regular maintenance on the R1.
New dust seals should be installed every time you install new bearings though.
martinc is offline   Reply With Quote
Old 06-09-2003, 08:26 PM   #6
tidbit
Forum Moderator
tidbit's Avatar
Bikes: We got digz
adam.. I wanna put some hids on my r6.. it's gonna require welding to my race faring stay.. and cutting/molding my sharkskin upper... i just need to find some projectors cheap and i cant find any.. lmk I have money to burn
http://www.r1-forum.com/sig/tidbit.jpg
03 R6 - Bone Stock
02 R1 - Bone Stock
00 R6 - Bone Stock
86 Rebel 250 - Bone Stock... seriously!
tidbit is offline   Reply With Quote
Old 06-10-2003, 10:20 PM   #7
VinR1
VinR1's Avatar
Bikes: 95 YSR50, '99 R6, '01 R6, '02 748, '00 996, '99 R1, ' 01 R1, '04 R1, '06 coming soon?
what?!?! can I use my factory spanner wrench to tighten?
VinR1 is offline   Reply With Quote
Old 06-10-2003, 10:29 PM   #8
Pfunkadelik
Pfunkadelik's Avatar
Bikes: ZX-10R
... just had the same problem. i snugged mine up, and it kept clicking after time. pull the lower bearing nut COMPLETELY off and looked at the threads. i found very tiny shavings and found the threads on the nut were no good. replaced the nut, and have had no other problems.
Pfunkadelik is offline   Reply With Quote
Old 06-10-2003, 10:31 PM   #9
Pfunkadelik
Bikes: ZX-10R
....by the way... got your shirts. they are SWEET, and good quality. thanks!! already have seen another guy that lives in my area wearing the same shirt after i got mine. DAMN!!
