2nd gear noise when shifting : Yamaha R1 Forum
Graves MotorsportsSportbikeTrackGearMotorcycle.com Classifieds!Motorcycle.com
SportbikeTrackGear
Old 06-09-2003, 04:35 AM   #1
da_lost_pinoy
nO FAT CHICks
da_lost_pinoy's Avatar
Bikes: R1 r1 R1
Question 2nd gear noise when shifting
I have a 99' R1 with 13k miles. You hear a grinding noise when shifting to 2nd gear at high rpm's. It does this sometimes shifting to 3rd gear also at even higher rpm's.
My question is this a clutch or transmission problem? Bike was just taken from winter storage 3 weeks ago and havent changed the oil as of yet.
da_lost_pinoy is offline   Reply With Quote
Old 06-09-2003, 01:25 PM   #2
Liv2Ride
2 wheels are better than 4.
Liv2Ride's Avatar
Bikes: Mighty Blue '02
I would try changing your oil and see if you still have the problem. Also, when you start the bike, pull in the clutch and put the bike in gear does it lurch forward? If so, you should try adjusting your clutch.
First thing is first, change that oil.
Let us know what happens.
Aloha
Liv2Ride is offline   Reply With Quote
