» Site Navigation |
» Motorcycle Forums
06-13-2003, 10:48 AM
#1
get what, get back
Bikes: 2003 ducati monster 620 dark, yellow 04 gixxer600
torquey twins
I'm not sure if this is the correct place to post this question...
What makes twins more torquey than other bikes? Also, how is it that the One (or any of the 4 cylinder sport bikes) is able to make so much more HP than, say, the Ducati 998 or 999?
any insight you can share would be appreciated
live forever or die trying
06-13-2003, 12:06 PM
#2
shoots! scores!!
Bikes: R1
itz not necessarily that they make more torque... the engines just make the peak in their torque curve lower in the rpm range.
to use more torque on an inline 4, you have to get the revs up and hence, inline 4s have more problems with wheel spin and you have to "conserve your tire". the higher engine rpms eat away at a tire more quickly.
disabling me will result in loss of primary power.
06-13-2003, 12:21 PM
#3
Ultimate Con$umer
Bikes: Current Bikes:1971 Norton Commando, 1971 Honda CL350 cafe, 1986 Honda VF1000R, 1994 Yamaha FZR1000 w/o 415 actual miles, 2002 Yamaha Grizzly 660, 2007 Harley FLHX Street Glide
In a nut shell:
V twins
longer stroke
bigger flywheel
larger individual cylinder volume
= more torque lower max RPM's
Inline fours
shorter stroke
smaller flywheel
smaller individual cylinder volume
= higher horsepower higher max RPM's
This is really in a nutshell but I'm not prepared to get into max piston velocity's and flywheel effect etc....
| Sponsored Links |
| Thread Tools |
| Display Modes |
Linear Mode
