» Site Navigation |
» Motorcycle Forums
07-13-2003, 12:18 PM
#1
Bikes: 2002 r1
grave velocity stacks
i need to know if ive done somethin wrong or what. ive put the velocity stacks the 2 middle hole of the air box to the throttle bodys when i put them i noticed a noticable loss in low end.
could it be my bike makes more power with out them? i bought to gain and i put it on the dyno this weekend up here in maine. my reading was 134.5 i have about 1200 miles on it but ive been on to it good after 300 miles i know its stil going through break in or what not but my friends stock 02 R1 ran 136 on the dyno last yr. mine has a jardine slipon and the grave velocity stacks. should i take them out? if so ive tossed the stock ones thinking i wouldnt need them. it would wheelie easier before i put them in and now i have to tug a little bit in 2 nd with it down a tooth in the front. i havent called them up yet but im going to to see what i should do. ill admit i have the slip on and the stacks but no power commander and thats the only thing i could think would make it seem like it lost power some how. i didnt do the pc because they said i would be alright with what i had and i would get a 2 horse power i also have mention the toque on my bike was only 71.2 and the stock R1 my friend had made 78? i did notice a drop but im taking apart and checking stuff out tonight any suggestions? i do not want to buy a pc if i can help it because the only map ill run would be a custom what work for some may not for others. was there something else i had to do when i did the stacks ?anyone notice this before
07-14-2003, 03:07 PM
#2
Bikes: 99 R1/07 1098S TRE
You are starting top add parts that would require a PC3 my friend;
I bet your motor is gasping for or fuel,or air.....got to see a chart.
07-14-2003, 03:16 PM
#3
WHO STOLE MY DAM BIKE
Bikes: 2002 Liquid Silver R1 STOLEN
kyle racing has pc3r 's at a good price give em a call they install on the bike in 30 min well worth it
2002 Liquid Silver R1 ....Greggs Custom Led front signals, Ixil Titanium Super Racing 50mm High Mount Pipe, Clean Tail Blinkkers Inside Tail , Catz Plazma Bulbs, PcIII R K&N Stacks and Dyno Tune, Schnitz Mirror Eliminators, Zero Gravity Dark Smoke Screen, Speigler Black and Gold Anodized Braided Stainless Brake Lines, Motovation Frame Sliders, Motovation Clutch Slider, Yamaha Factory Seat Cowl, Erachie Bar Ends, and Ohlins Steering Dampner W/ Harris Mount ~ ...I Want More What Can I Get Next???
07-14-2003, 05:17 PM
#4
Bikes: 2002 r1
when i had it on the dyno the guy said it was running lean. he could tell cause it was it was heating up fast, not over heating just heating fast every time he got on it i just want to know could i be going the other way (losing hp) running both of these together? it went better before i put them in with just my slip on. my dyno made me sick i expected 138-140 with this set up
07-16-2003, 06:08 PM
#5
Bikes: Yamaha R-1
If you think that the stacks are the problem then please call our staff @ graves and they will be glad to help you. We have had only positive results with this product. Chuck
www.gravesport.com
07-16-2003, 06:21 PM
#6
My one is me!
Bikes: 2003 ONE
it sounds as though you need to change your fuel map...
buy a PC3R
_________________________
2003 BLUE ONe, Devil high-mount Exhaust, Scott's Damper, Intuitive Frame & Swingarm sliders, ZG DUB BUB
07-19-2003, 07:21 PM
#7
Bikes: 2002 r1
i called your staff they was very helpful and i took it back apart to check it out it looked like it was ok with me but i havent rode it yet but my friend did tonight and said the thing go wickied good maybe i had a line pinched ? i left them in and when i got the extra $ im going to go with a pc and custom map they said she runs lean ? but thanks for you reply and again they was a big help
07-19-2003, 07:26 PM
#8
good people over at Graves
| Sponsored Links |
| Thread Tools |
| Display Modes |
Linear Mode
