Strange Rattling Noise : Yamaha R1 Forum
Old 07-16-2003, 07:43 PM   #1
cotton133
My CBR ate the R1
cotton133's Avatar
Bikes: '99 R1 sold'02 RC 51 '04 CBR 1000RR
I have a '99 R1 w/ 18000 miles. About 300 miles ago it started making a strange rattling sound. The power does not seem affected but the rattling is very noticeable. The sound gets louder and louder the warmer the motor gets. It almost sounds like the timing chain is slapping around inside the motor. I have replaced the timing chain tensioner to no avail. Any advice is greatly appreciated. Thanks.
cotton133 is offline   Reply With Quote
Old 07-16-2003, 08:00 PM   #2
Mr Evil
Just let me think about that !
Mr Evil's Avatar
Bikes: 2001 R1
Is the rattle always present ie; neutral/in gear, low rpm/high rpm, in sync with engine rpm, engine loaded or free spinning, on left or right (presume its on timing chain side), what does it sound like its in sync with, remember cams rotate half the speed of crank, have you changed the oil? Is it clean?.
Supply as much details as possible for a more accurate response of what the problem may be.
Billet top clamp-custom billet damper mount-full Ti muzzy-jet kit-airbox mod-AFE filter-flow commander-ported-R1 carbon grips-carbon tach face-custom billet bar ends-gilles rearsets-custom paint-flushmounts-anodized disk centers-all suspension re-valved & resprung-rear suspension link-tinted screen-seat cowl-afam 47 rear-180/55 rear-chrome levers-chrome top/bottom clamps-braided brake lines-heat wrapped headers-xenon globes-tank bra-did I miss anything?
Mr Evil is offline   Reply With Quote
Old 07-16-2003, 08:06 PM   #3
cotton133
My CBR ate the R1
cotton133's Avatar
Yes the rattle is always present. The noise is louder at higher rpm's than it is at lower rpm's. The oil has been changed. The oil looked very clean when it was changed. The noise seems in sync with the rpms of the motor. The sound seems to be coming from the right side top of the motor. Would this be valve noise? I have not had the valves adjusted. The noise is the most apparent when letting off of the throttle.
Old 07-17-2003, 03:27 PM   #4
r1-da-sht!
r1-da-sht!'s Avatar
Bikes: 99- r1 - red/white
check you head. possible bad lifter spring or valve issue. or we'll hope not but if it has a slight knock a piston might be going. at 18000 miles you are about do for a valve adjustment. on average its every 20000. but it depends on the rider/ owner.
r1-da-sht! is offline   Reply With Quote
Old 07-17-2003, 04:43 PM   #5
martinc
martinc's Avatar
Bikes: 99 R1/07 1098S TRE
Cam chain looseness sound disappear while engine reaches its OP temp.
It must be a loose valve.
martinc is offline   Reply With Quote
Old 07-17-2003, 06:26 PM   #6
cotton133
My CBR ate the R1
cotton133's Avatar
Thanks for the replies. I was planning on taking it to the shop to have a valve job done but I was a little apprehensive to have any more work done to it if it was a major motor problem. I will let you know how it turns out.
Old 07-17-2003, 06:46 PM   #7
Kirk
Young at heart
Kirk's Avatar
Bikes: '98 R1 gone....04 R1
Just make sure you explain it to the guys at the shop and they will keep an eye out for anything astray when doing the valve adjustment.
Kirk is offline   Reply With Quote
Old 07-28-2003, 08:22 PM   #8
cotton133
My CBR ate the R1
cotton133's Avatar
I got my bike back from the shop today and I got some bad news. I was told that the noise was not a valve but the cam chain. The mechanic told me that he warmed the bike up and the strange rattling sound became noticeable once the bike reached proper operating temperature. He also said that the cam chain noise would start once the bike warmed up. MartinC has told me the exact opposite. From everything I have read and heard MartinC really seems to know his stuff. Is my mechanic incompetent? Should I take it somewhere else to have another mechanic to look at it? Thanks again.
Old 07-28-2003, 08:30 PM   #9
Kirk
Young at heart
Kirk's Avatar
I'm no expert on this but it may just be the tensioner. I know there is an aftermarket one that you can just bolt on. Pm Martin if he doesn't reply to this thread. I remember reading something about problems with tensioners somewhere but can't remember the details.
Old 07-29-2003, 03:43 AM   #10
martinc
martinc's Avatar
What I"d do if I were you:
Go back there,talk to the service manager (not the mechanic) and have him diagnose the problem himself;if he come the the same conclusion,let him do the work but have him write on the wrok order that the job is free if its not that...or the amount is applicable on a valve job.(but I take that they checked it).
Keep in mind that not all problems give the same symptoms.
Old 07-29-2003, 04:18 AM   #11
cotton133
My CBR ate the R1
cotton133's Avatar
Thanks for the replies. I have replaced the tensioner but it did not help. I will take the bike back and do as you said MartinC. Thanks again.
Old 07-29-2003, 09:47 AM   #12
R1Jim
Bikes: 00 R1, ZXR750L1
does it clatter worse on the over-run than on the power, this would indicate to tensioner. Check it again, ensure it is extended and puting tension on the chain, remove timing inspection cover if necessary to verify.
sounds very like tensioner to me (but sounds arent always easy to interpret via text)
Rehab is for quitters
R1Jim is offline   Reply With Quote
Old 07-29-2003, 09:52 AM   #13
cotton133
My CBR ate the R1
cotton133's Avatar
I think it is the tensioner as well but I have replaced it already. The tensioner was used from another bike that did not have the rattle. The only other experience I had with a worn out timing chain was in an old nissan I used to have. It sounded bad when it was cold but the noise got less noticeable when it reached the proper operating temperature. The noise does seem more noticeable at idle when you are revving it.
