» Site Navigation |
» Motorcycle Forums
| Stunters Corner For all the R1 stunters out there.. share your knowledge, talk about it.. those that do not like stunting, please stay away |
06-11-2002, 10:48 AM
#1
We say Uz a WanksTa...
Bikes: 04 Silver Beauty--
How do I learn rollin' stoppie (I can come to stop and lift the rear---but I can't come to a rolling stop)????
06-11-2002, 10:51 AM
#2
svenne
Bikes: RSV Factory (street), R1 SBK (racing)
lots of speed and guts.
make sure the asphalt aswell as your front tire is sticky. Then you can just press harder and harder and eventually you'll find yourself in a rolling stoppie.
06-11-2002, 11:04 AM
#3
Bikes: 01 CLE R1
Yelp, it's usually best to do it on Concrete or fresh (less than 2yrs) asphalt. Start with speeds of 10 to 15 and gently pull in the front brake while lifting your ass off the seat! Squeeze the tank with your thighs. Just parctice doing this and you'll be a pro doing one handers in no time. If your serious about it, get ya a dunlop slick, alot of people will have different opinions but I find they work the best. Let us know how it comes.
#4
Dark Horse
Bikes: Huffy 10-speed
If you do it like Swedie said, you're in business. If you grab a fist-full-of-brakes, you're in trouble. The key is speed. Rolling stoppies are easier to control the faster you are going.
06-11-2002, 07:19 PM
#5
THE MAN
Bikes: 00 R1 (THE FASTER BLUE ONE)
Rolling stoppies
This is how I do rolling stoppies.
You will need a good front tire. i don't care who makes it as long as it sticks. It needs to have the proper air pressure in it, and you need to have forks in good working order. Also note this will wear on your steering head bearings, and make a not to lovely noise when the rear tire hits the ground if you still have the bike in gear. It makes less noise if the bike is in neutral.
Start out at whatever speed you like, keeping in mind the faster you go the less of a rush you will be in as you have more speed, and hence more time to work with.
What you want to do is to get the rear off of the ground without shocking the front tire. You want to get your speed to whatever you want it, pull in the clutch and down shift to first, then squeeze the brake lever. you want to feel the bike's nose dive. It should dive smoothly, not all at once. Keep in mind you do NOT want to shock the front tire, you want to transfer the weight of the bike onto the tire smoothly. when the front end is dived down you will want to roll into the brake lever. When I say "roll into" I am meaning to squeeze on the lever progressivly harder and quicker.
You will feel the rear end lift. Then it's time to smile. It is easiest to do at about 40mph or so. At that speed you have enough time to transfer the weight to the front tire with out scrubbing of so much speed you have nothing left to lift the bike with. Best bet is to pratice it several times soft and easy. It is more important to be smooth on the brake lever than anything else. A quick grab at the lever when the tire is warm will usually get the rear end up, but it will be much harder to controll / ride out.
Make sure you are forward on the seat, and your crotch is up against the tank. Once you get the smooth brake lever thing figured out you can add speed and rear tire height to it and ride them for longer. I will warn you though if you get it up too high while going fast (over 40mph) the front tire will try to tank slap and thats a bad thing. If you started a stoppie out at 80mph then the rear tire would not be coming off of the ground until about 65mph, you see what I am saying. make sure you are transfering the weight onto the front tire smoothly. It is much easier to controll that way, and you can work you way up to better and better stoppies with less fears of crashing.
Be forwarned, sometimes the tire will lock up on you. Sometimes even after the rear tire is off of the ground. It is no big deal just roll off of the brake lever. Smoothly. If you drop the brake lever and tense up you will cause yourself problems.
06-13-2002, 09:19 PM
#6
Bikes: '02 R1
I was always told to preload the front a bit, i.e slow down a bit to ease weight forward, then give it a good firm pull on the brake, careful not to lock it up.
2002 R1
Full Race Akrapovic
PCIII, custom map
06-17-2002, 07:49 AM
#7
Objects in the mirror.....none
Bikes: 2007 R1 Blue 2003 R6 Full Race CCS #294
Just like this!
06-17-2002, 08:29 AM
#8
That's what they say!
Bikes: 2002 R1 (blue) cause its faster and looks better
Show off!
PCIIIr, 520 chain conv, Graves Stacks, Chrome wheels, Micron blue to silver fade, Intutive frame sliders, Graphic Moto Flusmounts (front), Short Stalk V (rear), Lite N Boltz, Tankslapper (tank protector)
Air horn, Second Look seat skin
06-22-2002, 09:45 PM
#9
On the 7th Day GOD created R1
Bikes: Liquid Silver 2002 R1
Awesome stoppie Silver R1 dude
Not quite to that height on my stoppies yet, but getting closer. Need to get the camera out and see how high I'm getting.
06-29-2002, 03:31 PM
#10
Bikes: ī98 blue, what else
Hello guys and girls !
Iīm from Germany and i found your funny forum this weekend. I want to post a picture from my stoppie  . I donīt know how to do this. Please help  !!!
06-29-2002, 04:53 PM
#11
Ride safe boys.
Bikes: '02 R1 (Silver)
In the Reply section go to 'attach file'. Browse your computer til you find the file and then hit 'okay'. Then Submit. If you preview reply it will toss out the attachment so you will have to do it again. Hope this helps and welcome to the board.
06-30-2002, 02:08 AM
#12
Thanks to joemt
Here my little stoppie from Bavaria:
07-01-2002, 08:18 AM
#13
I think mine is higher!!
Just Kidding!!
Nice stoppie, you get them to roll at that height?
07-02-2002, 10:35 PM
#14
No, I almost stop the bike. I think itīs one of the funniest thing you can do with your bike but itīs not so good for the (I donīt know the english word for "Lager")
07-12-2002, 03:28 PM
#15
My other ride is your girl
Bikes: 02 R1 Liquid
endos endos endos
I loooovvvvveeeee endos. All variations, I will send some sweet pics of some feet over and one handers on Monday. Anyways, I skimmed through some of the others advice, my only additions would be to squeeze the tank with your legs. This will come in handy when doing high speed (80-120 mph) endos. You really need to get that weight of the handle bars when you are going to fast. It also helps when you start doing one handers and cross over one handers. Just my 2 cents.
07-13-2002, 01:49 AM
#16
Oh my god. Itīs really very hard to understand that difficult english posts. (Just for me, because my english is not perfect like yours). Especially some "nickname" like "endos" and so on...
So, did you (NCLunatixR1) send me some eMail with attachement?
Onkel
07-13-2002, 02:39 PM
#17
Faster than the CHP ;)
Bikes: Blue '05 R1
"Endos" are to BMXs (a bicycle used for doing stunts on) what "stoppies" are to motorcycles. Just different jargon... same thing though  Hope that clears it up
Full Akrapovic, Ohlins shock, '02 forks and triple clamps, Ivan's, ignition advancer, AFAM 520 conversion (+2 rear), DID EVR2, Scott's damper, SS lines (f&r), EBC Pro-Lites with PF 95's, Digi Gear, Attack rear sets and a bunch of pretty stuff
07-15-2002, 12:30 PM
#18
Riding is cheap therapy!!
Bikes: 2002 YZF R1 3rd one
Suspension settings for rolling endo
I have my preload set s little heavier than stock I weight 230 and have suspension set stiffer for the twisties. DO I want to lighten the preload off the forks to help transfer weight. My tire likes to skid more than any thing. Sometimes I get lucky and pull of a nice one.
The other night a lady asked me if I was all right after doing a rolling stopie she though I did not intend to lift the tire.
07-15-2002, 01:42 PM
#19
@SpdKlzU
Thanks
This is a really nice forum but very hard to understand even 50 % of it. (for me)
bye
07-17-2002, 11:47 AM
#20
Bikes: 02 R1 Liquid
endos
OK, for people having trouble understanding.
A stoppie is when you are at a complete stop and then the rear tire lifts off the ground. This is very sketchy and not a good thing to try. Usually a stoppie happens when you are not going fast enough. 25 MPH or less.
An endo is when you get the rear tire in the air and it rolls. This takes some practice. Here are some pointers.
Pratice.....ride at 45 mph and then pull your front brake and front brake only very hard. Odds are you won't flip over. You will just stop very fast. Practice this a lot.
Now you are a little used to the front brake power. Try this now....
1.) Find a road with no traffic that is no slick.
2.) Ride at 50 mph.
3.) Grip the tank with your knees hard, lean a little forward.
4.) Shift into neutral.
5.) Apply small amount of preasure on front brake.
6.) Now, this is the hard part. Apply a lot of preasure on the front brake, feel the balance of the rear end over the front tire.
7.) Continue doing this until you feel comfortable.
Soon, you will get to a point when you feel like you can let off the brake and still roll in the air. Remember this point. That is the point of no return. It is very hard to get back from there. I have rolled many endos over and it takes a lot of practice. If you are not willing to lay down your bike, then don't do it. The odds of you messing up are good. You will most likely be fine, but it does a lot of damage to a bike. Happy endoing.
T
North County Lunatix
| Sponsored Links |
| Thread Tools |
| Display Modes |
Linear Mode
