Have a buddy help you out...
Fill the resi up to full level. Close the lid. Put a towel under the calipers on each side so no brake oil gets on your wheel or tire.
If you are bleeding the front.
There is one pressure nipple on each caliper. DON'T OPEN IT... Find the nipple on each side. Find a wrench that will allow you to open it... DON'T OPEN IT.
Adjust one caliper at a time and then alternate L to R.
1. Have your pal Squeeze the front brake hard 5-6 times and hold the brake hard. I alway talk out loud to let the other guy know what you are doing. Yell BRAKE CLOSED.
2. Very Slowly open one nipple . You should see an air bubble come out. Tighten the nipple again. Yell to buddy, TIGHT., OK your turn.
3. Repeat for each caliper 3-4 times.
Same for process for rear.
You should never be spurting oil out. JUST BUBBLES AND THEN CLOSE THE NIPPLE... Adjust till you have the firmness desired.
"Big Head Todd"
04 Red R1
