Remote start help, '04 R1 : Yamaha R1 Forum
Old 05-09-2004, 12:00 AM   #1
SilverR1_2004
SilverR1_2004's Avatar
Bikes: 2004 Yamaha R1 - Silver
I'm almost done installing this alarm plus remote start, I just can't get the remote start to work. I think it has something to do with the last wire, it says "Blue wire to starter wire". Now, I tried tying in the Blue wire to the blue/white wire that feeds to the starter switch, but it's not working. Everything else seems to work, I hit the button to attempt remote start, the insturment cluster comes on, but the bike does not attempt to crank. Any Ideas???? alarm and ignition kill portion work fine.
SilverR1_2004 is offline   Reply With Quote
Old 05-09-2004, 12:37 AM   #2
Eyespy
Action figure sold separately
Eyespy's Avatar
Bikes: Red/White/Black 2004 R1 (track), Silver 2004 R1 (street), Red/White/Black 2000 R1 (track), 1987 FZR 1000 (street), 2000 black white and chrome Harley Davidson FLHTPI , 2002 XR400, 2002 XR50 (x2)
It sounds like the way you wired it to the wire to the starter switch, the circuit is not closed unless the switch is depressed, so the remote starter feature is defeated. try attaching it to the starter wire at the other side of the switch.
<a href=http://www.r1-forum.com/gallery/data/514/39eyespy_sig_pic_silver_630x120.jpg target=_blank>http://www.r1-forum.com/gallery/data...er_630x120.jpg</a>
____________________________
IOFFIO/MBBM
My Bikes Website
My Audio and Home Theater Website
Eyespy is offline   Reply With Quote
Old 05-09-2004, 10:38 AM   #3
SilverR1_2004
tried that first, didn't work either.
Old 05-09-2004, 12:54 PM   #4
K-zooR1
K-zooR1's Avatar
Bikes: 2008 R1/2003 Ducati 999
not sure how the stater kill works but you may be on the wrong side of that connection. if the remote start doesnt actualy deactiviate the starter kill, then that would be the problem. does the crank wire run through the alarm in any way? if so try and hook the blue wire somewere between the starter and the spot you connected the starter kill to. a thing to try is to proble that blue wire and use the remote start and see if it actualy gets 12V as if its trying to crank the bike. If not, you may have a problem with the remote starter.
K-zooR1 is offline   Reply With Quote
Old 05-09-2004, 01:08 PM   #5
SilverR1_2004
Something probably went wrong with the remote starter like you said. At first when I tried to use remote start I would get a quick jolt of 12v on the blue wire with the meter, but I get nothing. However, when I was getting voltage, it didn't work then either.
Somthing else odd, maybe someone can explain. When I hit the remote start, even if the blue wire is not attached, the instument cluster comes on and I have power to the normal starter switch, if I hit the starter button manually, it will crank, but won't start. This can possibly be engine kill thru the alarm?? I don't know, this is frustrating.
I was hoping to find someone else with an '04 R1 that successfully got it to work so I can be told exactly what to do. Maybe something different on this bike that prevents it from working this way.
Old 05-09-2004, 02:30 PM   #6
K-zooR1
K-zooR1's Avatar
there may be more than one wire in the run position. im not sure about bikes, never did one on a bike but did it on a tone of cars. 1st thing to try, i doubt it but, put the key in the ignition. dont think US spec bikes have a transponder like UK's. but hey, give it a shot. also, do here the fuel pump? what did your starter kill actualy wire to? PCM? if so that could kill anything, spark, fuel, anything...do you still have 12V to that blue wire? give this a shot. probe the crank wire and hit it. is it a 12v+ switch or a ground? it may be a ground switch which would be why your remote starter now no longer sends 12V . if it is 12V+ when you hit the starter button, find out wich one is 12V+ when you are in the run position and which one has nothing. then hit the switch and make sure the other one is 12V+. hook the blue wire to that if the blue wire is still giving a 12V+ when activated. try it with the alarm off first. one thing at a time.
Old 05-09-2004, 06:03 PM   #7
gsxr1000killa
gsxr1000killa's Avatar
Bikes: 12 R1, 08 Gsxr 1000, 02 R1
I had this remote start on my o2 r1 it requiered 2 relays one to turn the starter over and one to trip the fuel pump it was quite difficult to install on my r1 but easy as hell ro install on my buddy's gsxr.
gsxr1000killa is offline   Reply With Quote
Old 05-09-2004, 06:05 PM   #8
gsxr1000killa
oh yea forgot to mention be sure to install the side stand kill function if not the bike will start in gear and jump off the side stand.
Old 05-09-2004, 07:31 PM   #9
K-zooR1
K-zooR1's Avatar
good tip. listen for the fuel pump when you use the starter. a note for any remote start, any wire that is hot 12v when the key is in the run position needs to be hot with the remote starter. check the wires behind the key cyl harnis.
Old 05-09-2004, 10:20 PM   #10
gabeowen
Resident H8R
gabeowen's Avatar
Bikes: A few.
That would so not be cool if that was the case. I also have an alarm system for my 01 R1 and I think I will just have the dealer install it. I don't feel to comfortable in those wires.
H8R.
gabeowen is offline   Reply With Quote
Old 05-09-2004, 10:29 PM   #11
RATED_XXX
The 02 R1 is very Rated `R`!
RATED_XXX's Avatar
Bikes: 02 Liquid Silver R1
What alarms are out there that have the remote start option?
I bought a used one that the sell at tricktape.com
Too many wires to hook up and no alarm shop would touch it.
RATED_XXX is offline   Reply With Quote
Old 05-09-2004, 10:32 PM   #12
gabeowen
Resident H8R
gabeowen's Avatar
Bikes: A few.
Kings Gun here.
H8R.
Old 05-10-2004, 10:23 PM   #13
SilverR1_2004
I think all the Thor alarms have remote start. I got model M302 for $40 on ebay
Old 11-22-2004, 05:22 PM   #14
alokin
Bikes: R1-04 lavared
IMMOBILIZER!!!!!! the key contains a chip, it cant start without it! you will have to disable the immobilizer function to get remote start to work!,,,
alokin is offline   Reply With Quote
Old 11-22-2004, 05:27 PM   #15
SilverR1_2004
i don't think so dude
Yamaha Motorcycles Victory Gunner Forum Victory Charger Forum Honda Vultus Forum HD LiveWire Forum Ninja H2 Forum Ducati Scrambler Forum Kawasaki Ninja 250SL Forum
