» Site Navigation |
» Motorcycle Forums
08-25-2004, 09:52 AM
#1
R1STYLE
Bikes: 2003 R1
03 Ho do I Remove Front Wheel
I know how to do it, does anyone know the exact size of the huge hex tool I'll need to remove the front axle from the forks and wheel?
Ride it like you stole it!
08-25-2004, 09:57 AM
#2
THEY CALLED ME SWEETNESS!!!!!!
Bikes: 2004 R1
Once you remove the bolt, you can just push the axle out...that's what I did.
08-25-2004, 02:43 PM
#3
El Assholio Supremo del Mundo
yep. dont even worry about the hex.
Remove the bolt on the other side, loosen the pinch bolts, push the axle out while supporting the wheel..
"I'm not concerned with your liking or disliking me... All I ask is that you respect me as a human being. " -- Jackie Robinson
Service Manuals
08-26-2004, 12:26 AM
#4
smooth=fast
Bikes: Blue 06 R1 -ya know the blue ones are faster
1 place front forks on front lift/stand.
2 loosen the brake calipers/fender attach and tie with a shop rag to aviod scratches on your rims.
3 remove the bolt from the r.h side -22mm *I think
4 loosen the pinch bolts on the bottom of the forks.
5 slide out the axle
6 holding the brake calipers away - remove the wheel.
7 check / confirm left and right side to install as same.
| Sponsored Links |
| Thread Tools |
| Display Modes |
Linear Mode
