Acumen DG8 install : Yamaha R1 Forum
Motorcycle.com Classifieds!
Old 08-27-2004, 04:40 PM   #1
JG1
E.A.G.L.E.S !!!!!!!
JG1's Avatar
Bikes: BMW S1000RR on order
Acumen DG8 install
How the heck to I route the long speed sensor harness under the tank to plug it into the the white 3-wire connector? I can't find ANY room under the frame to slip this damn thing in. and route it to under the tank.
EDIT: Figured it out. I had to go threw the left side of the bike to get it under, I was trying to get it under the right side frame.
JG1 is offline   Reply With Quote
Old 08-28-2004, 08:37 AM   #2
martinc
martinc's Avatar
Bikes: 99 R1/07 1098S TRE
Good...patience is the master word here when dealing with electrics.
It has to be done very well in order to last.
martinc is offline   Reply With Quote
Old 09-02-2004, 09:25 AM   #3
Kanadali
Old-timer
Bikes: 2004 R1
Question
JG1,
Did it work? I cannot get mine to program. I also have a PCIIIusb, and I am wondering if there is a conflict between the two. Alternately, I may have a defective DG8 unit.
Kanadali is offline   Reply With Quote
Old 09-02-2004, 09:55 AM   #4
JG1
E.A.G.L.E.S !!!!!!!
JG1's Avatar
Yeah, worked fine. I programmed it per the instructions that came with it.
Sure your doing it right?
Old 09-07-2004, 01:54 PM   #5
accce
3-2-1 GO!!!
accce's Avatar
Bikes: 03 R6 sold, 03 R1 gone, 04 R1 sold, ?
How long did it take to install?
Ride On!!!
accce is offline   Reply With Quote
Old 09-07-2004, 03:04 PM   #6
JG1
E.A.G.L.E.S !!!!!!!
JG1's Avatar
30 minutes or so
