» Site Navigation |
» Motorcycle Forums
09-07-2004, 12:38 PM
#1
Bikes: 04 Yamaha R1 and 03 Gsxr1000 Dragbike
04 r1 not shifting smoothly.
has anyone had this problem? i have about 2,000 miles on it and it doesnt shift as smooth as it did brand new. it seems like its a little harder to shift now. if use to just slide in gear, almost with out having to clutch it.
Mods: Akr full Evo exhaust, PC3 USB, , custom map, Graves velocity stack, graves smog off plates, 520 conversion kit, Gregs flushies, Rear intergrated led, Yama solo seat, Pilot powers, 16t front and 47th rear sprockets, high performance clutch springs and custom garage door opener
09-07-2004, 01:19 PM
#2
Always getting faster...
Bikes: '01 R1, '98 Kawi EX500
Maybe try switching to a synthetic oil?
1986 Kawasaki Ninja ZX-6R
2001 Yamaha YZF-600R
2001 Yamaha R1
2001 Yamaha R1
1998 Kawasaki EX-500 (track)
09-07-2004, 01:20 PM
#3
Wherd the road go
Bikes: R1
what highside said with a descent oil filter. you'll feel the difference right away.
09-07-2004, 01:39 PM
#4
obsessed
Bikes: Red 04' Duc 999s, B/R 06' GSXR 1000, B/Y 04' GSXR 750 track bike, Black 03' Fat Boy, White/Silver 08' SE Ultra
after about 2,000 miles mine started getting stuck in neutral a lot. It still does but it's much better after a fresh oil change. I'm going to switch to synthetic next time too and maybe look into a better filter.
Nesba A #69
R.I.P. - Kelly "K-FleXXX" Brown 6-15-2006
R.I.P - Glenn "Elvis" Breaux 6-17-2007
R.I.P. - Chad "GAWarrior" Clifton 6-25-2008
09-08-2004, 05:37 AM
#5
whats the best synthetic to run? also how many miles before i can use it?
09-08-2004, 04:54 PM
#6
Forum Moderator
Bikes: '06 Raven R6
Everyone has their preference on what synthetic to use. I have
always had great luck with Mobil One 15W50 in the red cap. It
costs about $4.50 per quart at Wally World. I waited until I had
5K miles on my bike before I made the switch. I've never had the
first problem of any kind. If you have 2K on your bike you should
be ok to put it in. Lot's of choices along with prices that are very
steep. Try doing a search on synthetic oil. It's been covered here
many times.
Rest in Peace Glenn "Elvis" Breaux - June, 17th 2007 and Chad Clifton - June, 25th 2008. You will always be with me when I ride. I will never forget you.
09-08-2004, 05:18 PM
#7
Bikes: None Currently
Make sure your shift rod isn't binding. After I had the rod off to change the sprocket, I over tightened it and it binded and caused shifting problems. Funny how something so smalll can sometimes be the problem.
RIP my friends: Airknight, Brian, K-flexx, and Dxextreme..
Please ride safely, the street is no proving ground
09-08-2004, 06:14 PM
#8
Luv Buggin Yammy Drivers!
Bikes: Kawasaki nut and thats all! Hate all others!
Re: 04 r1 not shifting smoothly.
One of yer bearings prolly dropped in the tranny!
"Ya Gotta Have Big Ones!"
http://www.speeddemons.com/home.html
09-08-2004, 07:48 PM
#9
Its time to catch up GIXXER
Bikes: Yamaha Nouvoe 115AT.R12004
Get Semis -Syn it will get better .... No probs with Castrol Semi -Syn
SupraSonic
09-08-2004, 09:10 PM
#10
My R1 makes me happy!
Bikes: R1 2004
Dude! MOTUL full sintetic racing oil,use it and your bike is gonig to be smooooth!!!
LIFE BEGINS AT THE END OF YOUR COMFORT ZONE....
09-08-2004, 09:24 PM
#11
Red is faster!
Bikes: 2004 Yamaha R1/2000 Yamaha R1/2003 Yamaha R6
 Motul 300V is great and smooth as silk with the shifting!
http://www.9mileracing.com | r1rider@9mileracing.com
Sponsors: 9Mile Racing, LP, Sharkskinz, Graves, Dunlop, Chicken Hawk
09-09-2004, 12:29 AM
#12
working on that new bike
Bikes: Trek 4200...not as fast as the R1
many times.
I resisted against synth oil forever.
then I tried castrol R4 superbike...didnt like much at all
then searched via forum and decided to give mobil a chance...in love..have over 2000 miles on this oil change and its still clean and clear...shifting has noticably improved.
also for the guys getting neutral stuck...adjust your shift rod down 1/8 of a inch...incredible difference
I was having same issue in power running my bike and a mamber suggested doing this...I never get stuck in neutral any more
09-09-2004, 05:35 AM
#13
what about maximas ultra full synthetic oil? is it really good?
09-09-2004, 05:37 AM
#14
Heh Heh, Alright!
Bikes: 04 Silver R1
be ok to put it in.
09-09-2004, 05:41 AM
#15
Bikes: 04 R-1
its not your oil at all, the tranney is working itself in. Mine did the same thing but after 2500 miles or so it went back to being smooth as silk, so synthetic oil is not needed, and it also costs a bit more.
09-09-2004, 12:54 PM
#16
it doesnt feel like a tranny working itself in. i cant see how a tranny can be smooth then get tight, then go back to being smooth.
i did change my front sprocket, i will check the linkage again and see.
09-09-2004, 05:35 PM
#17
Bikes: 04 R1
I HAD THE SAME PROBLEM WITH MY 04 R1 AND 4000MILES LATER MY CLUTCH WAS SHOT THEN WHEN I PUT A NEW CLUTCH IN I LOOKED AT MY OLD CLUTCH PLATES AND THEY WERE ALL WARPED I THINK THERES SOMETHING WRONG W/THE NEW R1S GEARING OR SOMETHING CAUSE IM NOT THE ONLY ONE WITH THIS PROBLEM
09-10-2004, 05:30 AM
#18
well i will check the clutches this weekend and change the oil to synthetic also. i will keep you guys posted.
09-14-2004, 08:53 PM
#19
Socialist Liberals Suck
Bikes: Blue '98 R1 Sold, Red '01 R1 Sold, Silver '04 Sold.
I'm going to change to full synth also. I'm having a hard time going from 2nd to 3rd under hard acceleration... hope it helps some.
-Freak
Bikeless.... for now.
09-15-2004, 07:53 AM
#20
i still havent had time to to change the oil. i will definetly do it this weekend. i will keep everyone posted. i order some maxumus extra full synthetic oil. also some engine ice. i want to see if i can keep the temp down on the bike also. its not really getting super hot or anyting just want to give it a try.
| Sponsored Links |
| Thread Tools |
| Display Modes |
Linear Mode
