» Site Navigation |
» Motorcycle Forums
07-22-2002, 10:17 AM
#1
Pro Racer Mode - Enabled
Bikes: 2001 R1
is there a right or a wrong way to install spark plugs? Do you just screw them in, or is there a given amount of turns you need to do?
07-22-2002, 10:47 AM
#2
R1
Bikes: '02 F4i, '04 R1
I don't have my manual with me...but I think it said it should be torqued at 8 or 9 ft/lbs....and if no torque wrench is available then had tighten by hand and then use the wrench and turn 1.5 times....
I'll check the manaul later when I get home to be sure....
07-22-2002, 03:03 PM
#3
Bikes: 99 R1/07 1098S TRE
what i do is go as hard as i can with my hand,then use a ratchet and tighten for no more than1/4-1/3 turn.
1.5 is dangerous to strip the head,and we all know what it means.
just lightly tight.
| Sponsored Links |
| Thread Tools |
| Display Modes |
Linear Mode
