Hello, R1 Forum... I Need Help With 98 R1 Carb Issues - Page 2 - Yamaha R1 Forum: YZF-R1 Forums
98-99 R1 Mechanical Help Mechanical and Critical Issues for the 98-99 R1
 2Likes
post #21 of 29 (permalink) Old 05-05-2019, 11:42 AM Thread Starter
My R1 is the original 1998 R1.
Nah, carb cleaner worked for a bit. I was elated. Start from cold. Tick-over perfect. Throttle response perfect. After a couple of hours, restarted and misfire. Petrol overload from carb 1 and 2. I've already done two big cans of carb cleaner which works for a bit, but then not. Time to take the carbs off if I can get at the hex screws ! It's like this bike costs me more when I don't run it then when I did. Why can't petroleum distillers make a purer product ? Dino juice does not forgive.
RINJR is offline
post #22 of 29 (permalink) Old 05-06-2019, 05:29 PM
Jimmy boy's Avatar
Glad you got it all worked out! Now go ride the wheels off that thing. Sitting is what clogs everything up✊
Jimmy boy is offline
post #23 of 29 (permalink) Old 05-07-2019, 11:38 AM Thread Starter
O-KEY-DOUGH-KEY
I now have a ball-ended 3mm hex key at 125mm in length. And, some assorted jet cleaning brushes. I'm hoping that that will assist me. Whilst I do have what my son calls, "sausage fingers" his, are not, yet. So! A brilliant idea; let my son undo the 3mm carb body to inlet manifold screws instead of me. I have four old socks at the ready. Let's hope nothing drops inside that vertical inlet manifold though, eh ?
Jimmy boy likes this.
RINJR is offline
post #24 of 29 (permalink) Old 05-11-2019, 06:27 PM
Jimmy boy's Avatar
Petrol company could give a shit about us.
post #25 of 29 (permalink) Old 05-14-2019, 08:03 AM Thread Starter
Sunday ! My only day off (get the violins out) and my son and I had a crack at the R1 again.
That 125mm ball-ended 3mm hex spanner / key was ace at attacking the carb array to inlet manifold clamps (I undid the top set of clamps, not the bottom set). The carbs didn’t come off easily. I had to use a length of wood as a lever against the frame to prise the carb bank off, jiggling the carbs as I did so.
Ok, undoing the choke outer cable stay-clamp but leaving the throttle cables intact and flipping the carbs of the R1 upside down was an easy thing; thanks for that tip, Sharksawyer.
Undoing the 3 screws that hold the float bowl on was a challenge. I had to use a hammer and the end of a small flat-blade screwdriver to wack the edge of the screws a bit to loosen them. Why don’t manufacturers fix ‘em up with hex screws ? Anyway, all that whacking damaged the screws, but hey-ho, all the screws unscrewed. I don’t possess an impact screwdriver and I’m not sure that that would be a solution anyway because one of the 3 float-bowl fastenings is quite thin on aluminium underneath. Most of the screw threads were corroded which I figure is the ye-olde electro-chemical interaction between aluminium and steel.
The floats were good though! No petrol in them and tested in a sink of water. The main jet housings were removed and cleaned inside with an electric drill fitted with an ear cleaning bud plus a dab of metal polishing liquid. I squirted carb cleaner into every other orifice I could find. I used-up about 12-15 buds for polishing I guess.
Next, the float bowl needle valve. The, “rubber” (it can’t be real rubber because the latex in the rubber would disintegrate in contact with petroleum-anything) cone of each needle valve was not obviously worn (although, under a microscope wear-and-tear would be evident after 20 years I guess). I removed the float bowl needle valve housing and found that the O ring seals were absolutely and totally shot. The seals broke up in pieces when I tried to remove them. I fitted each valve housing with a new green O-ring seal and polished inside the brass needle valve housing with ear cleaning buds and metal polish attached to a drill until they were absolutely gleaming like gold.
…I’m glad the weather here didn’t break. No cover or workshop for the bike you see. Working out in the intermittent sunshine graced with threatening black clouds.
So, now for a refit ! I didn’t change the float bowl gaskets which looked ok.
That was fast work! I think it was because of all the blackness of a thunderstorm looming above! I gently used a rubber mallet to tap the carbs back into place, rocking the carb bank back and forth slowly as I did so. Beforehand, I sprayed a bit of silicone spray around the “rubber” inlet manifold clamps to help the carbs slide home easier.
From start to finish, it took me and my son two and a half hours. Not to bad.
For those of you reading this, who like me, have never attempted this repair before on a R1, the best tools I had to get the job done were good quality ball-ended 3mm hex keys, long and short versions (~ 60mm & 125mm (ball–ended is important because the hex spanner key does not have to be absolutely perpendicular or parallel to access the head of the hex bolt.)) and a powerful mini led torch.
My R1 works well now. And when I’m not skint, fitting a complete carb overhaul kit is needed to do a pukka job. But as I want to get this bike on the road as soon as possible, I have to work with a miniscule repair budget. I am NOT missing yet another summer of warm twisty tarmac because I, “don’t have the money…” !
Next up is an oil and oil-filter change with a magnetic drain plug. I am absolutely convinced that petrol has seeped past the piston rings and into the engine oil. It must have. Besides, the bike has been standing for years and the oil will have degraded.
Following that, a new front tyre, which I quite fancy to be a Michelin Pilot Road 4 because I want a tyre that lasts longer riding more-or-less upright (I’ve a Battlax on the front at the moment). Why not something sticky you ask? Well, at aged 60, anywhere near that red line on the tacho is now out of bounds; seven or eight thousand rpm in any gear on a R1 is plenty for me. Why exactly? FEAR! Let me explain…
The last time I chucked the R1 down the road was when gave it too much squirt on a zero miles brand-new back tyre when turning a junction on a dry road. On an worn-in tyre that manœuvre would have been slingshot-impressive. But what happened was that that low-speed fall made my bones ache for months afterwards. Forget lifting the front wheel anymore too.
You see, when I was 20-50 years old, the outside of the tyre is where I lived. Now, I’m riding in a style to reach 80 years and remain fully intact too, I hope.
Have fun, always ride defensively, and thanks to everyone who has helped me get this carb job done.
Nick
RINJR is offline
post #26 of 29 (permalink) Old 05-14-2019, 08:29 AM
andrewstclair's Avatar
I think the needles are made of viton. the float bowl screws on the bottom usually do seem to sieze in there a bit and even in you have a Phillips in there and you hit it with a hammer it will usually relieve some pressure and Crack loose some of the corrosion in there and it helps even if it isn't the proper impact driver but it's hard to do with the carbs not in a vice with some soft jaws.
You may have said this and I missed it but how did the seats look where the needles make contact and did you Polish those up as well? Also did you happen to check the floats? 1 that they don't have any fuel inside them, when they get old they can Crack and leak a bit inside so they don't sit at the right height. 2 with everything on the carbs installed except the float bowls you can turn them upside down and look across to make sure the floats are all resting at exactly the same height and none of the tabs have been bent by someone previously maybe. That can give a similar symptom to a bad needle and seat.
09 R1 black/gold SOLD
2015 R1M 007
2016 R1 Track
andrewstclair is offline
post #27 of 29 (permalink) Old 05-14-2019, 02:28 PM
04
Sunday !
Nick
60 is very young...sticky tires are safe tires unless you ride in rain.
tory ii is offline
post #28 of 29 (permalink) Old 05-14-2019, 06:43 PM
Is there anybody out there?
Glad you got it going! When I can't get the float bowl screws out, a pair of thick Vise-Grips work quite well. I make it a habit of starting my bike once per week and letting it idle for a couple of minutes to keep the carbs from gumming up.
Mark
Sharksawyer is offline
post #29 of 29 (permalink) Old 05-21-2019, 11:36 AM Thread Starter
The needle seats looked like a coffee mug used daily that hadn't been cleaned for a month. No particle debris as such, just, "stained". Before I reinstalled the float needle valves, I polished the housing to gleam like gold. This will help to offset some wear in the tip of the needle valves themselves.
Ideally, I should have used new ones, plus new float bowl gaskets. Another day, and another dollar...
RINJR is offline
98 R1 Carb Sync and Other Carb Questions wjgrange 98-99 R1 Mechanical Help 2 07-22-2012 06:33 PM
carb conversion,sell or keep as carb j-star Mechanical / Help 8 12-10-2010 07:47 PM
Hello R1-Forum, and hello R1! ReauDog General Motorcycle Discussions 22 02-10-2010 01:07 PM
Hello hello hello, is anybody out there??????? KneeDragger77 General Motorcycle Discussions 18 11-28-2002 03:18 AM
