99 R1 Cant shift past 2nd - Yamaha R1 Forum: YZF-R1 Forums
98-99 R1 Mechanical Help Mechanical and Critical Issues for the 98-99 R1
post #1 of 17 (permalink) Old 04-15-2019, 12:44 PM Thread Starter
Cannot get the bike to shift into anything past 2nd. 1-N-2 shift perfectly normal, but when trying to go shift into 3rd it acts like something is blocking it. Any ideas as to what it could be?
Tyler Fallert is offline
post #2 of 17 (permalink) Old 04-15-2019, 02:41 PM
Just enjoy the ride.
Nsecure805's Avatar
Only way to find out is by taking it apart. Sounds like a bent shift fork. Or if your lucky maybe the shift shaft is busted and it isn't resetting properly when you shift.
1997 Yamaha YZF600R
2014 Yamaha R1
Nsecure805 is offline
post #3 of 17 (permalink) Old 04-15-2019, 03:38 PM
Super Duper Moderator
Kevap's Avatar
Yeah, that's exactly what it sounds like. Time to rebuild your transmission.
TEAM: SO SCARED NO LEAN
Kevap is offline
post #4 of 17 (permalink) Old 04-15-2019, 06:07 PM
Is there anybody out there?
I'd take a look at your detent spring on your shift shaft before tearing into the transmission. Could be broken.
Mark
Sharksawyer is offline
post #5 of 17 (permalink) Old 04-16-2019, 11:38 AM Thread Starter
Took the shift shaft cover off and this is what I found. The bolt was completely free. Is this what is causing me to not be able to shift into 3rd? What the heck would cause this bolt to rip threads and come free?
ID:	998033   Click image for larger version
post #6 of 17 (permalink) Old 04-16-2019, 11:48 AM
Nsecure805's Avatar
That may be your issue but I'm not familiar with the 99 r1. Most shift shafts I have seen are not bolted on. They are held in place with a clip or shifter on one side and the cover on the other. Where did the bolt come from?
1997 Yamaha YZF600R
2014 Yamaha R1
post #7 of 17 (permalink) Old 04-16-2019, 11:51 AM Thread Starter
You can see where it is supposed to bolt onto the the other side of that black plate inside the shift shaft compartment.
post #8 of 17 (permalink) Old 04-16-2019, 12:36 PM
Nsecure805's Avatar
I see, looks like some sort of support. What I would do is reinstall the shift shaft with the cover off. Try shifting through the gears. You may have to move the rear wheel to get it in gear. See what the shift shaft does when going to 3rd. If you see nothing wrong on that end of the bike and the it operates normally then it is your transmission. Try to see if that black bracket moves while shifting.
1997 Yamaha YZF600R
2014 Yamaha R1
post #9 of 17 (permalink) Old 04-16-2019, 12:39 PM
andrewstclair's Avatar
so most likely because the transmission is a common issue it may have been repaired once before and they didnt apply locktite to those bolts and they are backing out. it looks like it backed out then ripped out just the end of the threads. that drum needs to be pushed back in then the bolts cleaned up and holes cleaned out so put the lil red hose in the hole and spray some brake clean to get any debris out, blow it out with air to get it dry and apply some blue locktite and reinstall the bolts. it looks in the photos like the drum has backed itself out a bit and that could cause what your talking about because the forks become misaligned for the timing of the gear engagement. put it all back together properly and flip through the gears with the motor off rocking the bike forward and back or on a rear stand moving the wheel by hand to see how it is. riding it like that or having that misaligned at a worst case scenario can engage 2 gears at once and block the case apart to lock up on you so do it by hand before you test ride. let us know what you find out
09 R1 black/gold SOLD
2015 R1M 007
2016 R1 Track
andrewstclair is offline
post #10 of 17 (permalink) Old 04-16-2019, 12:41 PM
the shifter is part of the cover he has removed. you can see the shift rod linkage in the photo hanging with nothing to connect to.
2015 R1M 007
2016 R1 Track
post #11 of 17 (permalink) Old 04-16-2019, 12:46 PM
Nsecure805's Avatar
Thanks Andrew. Not familiar with this bike. Just throwing ideas out there.
1997 Yamaha YZF600R
2014 Yamaha R1
post #12 of 17 (permalink) Old 04-16-2019, 12:58 PM
You I read where you said that I was just pointing it out. That's the shitty part about this you kinda have to feel your issue out. Kinda like reading brail lol.
2015 R1M 007
2016 R1 Track
post #13 of 17 (permalink) Old 04-16-2019, 01:16 PM
Nsecure805's Avatar
I see the linkage in the pic but I still thought the shift shaft was a separate component and not part of the cover.
1997 Yamaha YZF600R
2014 Yamaha R1
post #14 of 17 (permalink) Old 04-17-2019, 06:36 AM Thread Starter
The bike has been fixed! After reinstalling the screw, took the bike for a ride and hit all 6 gears. Is this a new one in the world of, "my bike wont shift to 3rd gear"?
post #15 of 17 (permalink) Old 04-17-2019, 07:41 AM
Glad to hear. Did you use locktite this time?
2015 R1M 007
2016 R1 Track
post #16 of 17 (permalink) Old 04-17-2019, 08:04 AM
Nsecure805's Avatar
Lucky you. Could've been worse. Have fun out there.
1997 Yamaha YZF600R
2014 Yamaha R1
post #17 of 17 (permalink) Old 04-18-2019, 02:00 PM
Racer Dude's Avatar
Did you replace the bolt?
Bogie is the man, and I should learn not to mess with him
Racer Dude is offline
00 r1 won’t shift past 2nd Dan Johnson II 00-01 R1 Mechanical Help 0 08-08-2018 06:25 PM
Wont shift past 2nd gear.. RJ540 02-03 R1 Mechanical Help 3 10-16-2014 08:28 PM
getting past your past thephantom Off Topic Talk 20 05-25-2013 07:39 AM
Cant get this song out of my head for past week lol martywhynot Off Topic Talk 27 12-12-2009 03:12 PM
1st to 2nd shift; misses 2nd and hits neutral, which results in a loud CLUNK into 2nd Clovis General Motorcycle Discussions 6 05-15-2008 07:22 AM
