2002 R1 high idle once warm? - Yamaha R1 Forum: YZF-R1 Forums
post #1 of 17 (permalink) Old 12-18-2011, 06:18 PM Thread Starter
Hi everyone. Ive been searching around google for a answer to my problem but I can't seem to find an exact answer. When the bike is fully warmed up the idle will stick between 2k to 1.8k which seems really high. When I start the bike up it will usually idle at 1.4-1.5k which seems low since during warm up the bike should be idling higher correct? The bike has 19k miles on it and has a power commander and devil shotgun exhaust.
Im thinking it might be the map the power commander currently has stored on it. I tried lowering the idle via idle cable but it didn't help anything. Also what temperature is normal for this bike to be at fully warmed up? Is 220 degrees F correct? This is my first litre bike and I assume the engines get hotter compared to a 600cc.
Any input is appreciated.
DavieDarko is offline
post #2 of 17 (permalink) Old 12-18-2011, 07:03 PM
Throttle Happy
nicknoodles's Avatar
220 degrees is when the fan comes on, I consider the bike good enough to begin riding when it doesn't say "low" anymore(like 103 degrees)...and yeah you should be at a higher idle at initial start up and it should lower once warmed up...I'm assuming you use the choke at start up? And when you fully close the choke is when the idle increases? Silly question but are you maybe working the choke backwards??
Sent from my Motorcycle iPhone app
nicknoodles is offline
post #3 of 17 (permalink) Old 12-18-2011, 09:23 PM Thread Starter
There's a choke on my bike? I thought fuel injected bikes didn't have a choke.
post #4 of 17 (permalink) Old 12-19-2011, 06:10 AM
Throttle Happy
02 R1's are carbureted
post #5 of 17 (permalink) Old 12-19-2011, 09:18 AM Thread Starter
Theres no choke on the bike though...They discontinued the carbs in 01
http://en.wikipedia.org/wiki/Yamaha_...2.E2.80.932003
post #6 of 17 (permalink) Old 12-19-2011, 10:53 AM
ajust the idle when its warmed up to about 1000 rpms and see how it starts the next day when its cold
tirekiller is offline
post #7 of 17 (permalink) Old 12-19-2011, 10:53 AM
yield
xdonniedarkox's Avatar
There's carb/throttle slides and FI. Port piston style injection.
There is a idle screw adjustment at about 10 oclock of looking at the shift bell housing on the shifter side of the bike. Turn it an 8th of a turn youll be good
Asked if he was afraid of dying in an accident, Marco Simoncelli responded: "No. You live more for five minutes going fast on a bike like that, than other people do in all of their life." rip #58 ciao ciao bello
the art of the moto:
xdonniedarkox is offline
post #8 of 17 (permalink) Old 12-19-2011, 03:51 PM Thread Starter
Sorry fellas forgot to mention I tried lowering the idle using the adjustment screw but it doesn't do anything wether I turn it counter clockwise or cw.
post #9 of 17 (permalink) Old 12-19-2011, 03:53 PM
yield
Thats curious. Right raises, cc lowers. I believe its a cable. If you keep going cw does it raise the idle?
post #10 of 17 (permalink) Old 12-19-2011, 04:30 PM
MMM Meaty!
Waxer's Avatar
The idle adjuster might be off/disconnected at the TBs.
In most cases if you can't adjust it down the cold start solenoid is stuck and needs to be cleaned and/or adjusted.
To the "State of California" -You can have my "Akrapovic" when you pry it from my cold dead fingers!
|R1-014 Dragon Squadron| The Ouija Board asks me questions!
Waxer is offline
post #11 of 17 (permalink) Old 12-26-2011, 09:55 AM Thread Starter
Ill take the tank off tomorrow and give it a look around. Is the solenoid hard to get to?
post #12 of 17 (permalink) Old 12-26-2011, 06:12 PM
MMM Meaty!
Waxer's Avatar
No, just lifting the tank is all you need.
Waxer is offline
post #13 of 17 (permalink) Old 12-31-2011, 12:20 PM Thread Starter
You happen to have a picture of it? I tried looking up "cold start solenoid" in my clymer manual and can't seem to find it.
post #14 of 17 (permalink) Old 12-31-2011, 07:29 PM
MMM Meaty!
Waxer's Avatar
Left side, about mid tank, silver with two small water lines going into it. Has a screw adjuster, and part of it may or may not move with the throttle depending if it's stuck or adjusted right.
Waxer is offline
post #15 of 17 (permalink) Old 01-01-2012, 12:57 PM Thread Starter
Do you know the actual name for the part? I like to follow what the guide suggests. Is it adjusted with the bike on? Happy New Year btw!!!
post #16 of 17 (permalink) Old 04-14-2016, 07:28 PM
Did you ever fix this idle problem on your bike..mine does this and it does it when warmed up.. Idles low when cold..
germworm361 is offline
post #17 of 17 (permalink) Old 04-08-2017, 06:37 PM
Hey guys my 2003 Yamaha r1 has a similar problem but can't figure out what is wrong. The bike had issues starting. I ended up replacing 4 fuel injectors, 4 coils, and the fuel pump and removed the power commander. The bike starts now but idles bad. Idle set to 1.3-1.5. When the bike is warm and ran for a bit, the bike turns off. When I'm stopped in neutral the needle will start jumping from 1.5 to below 1 and then turn off. The only way the needle won't jump or bike won't turn off is if I set the bike to idle at 2-2.5. I know that is too high. Any suggestions?
Jesus Arce is offline
High idle after warm up jtbush78 00-01 R1 Mechanical Help 2 08-21-2012 07:44 AM
07 R1 won't idle when warm rustynutz Mechanical / Help 0 06-19-2009 08:30 AM
Rattle on idle when warm crk1 04-06 R1 Mechanical Help 2 09-15-2007 09:02 AM
Low idle during warm up TheOoz 02-03 R1 Mechanical Help 0 03-20-2007 01:46 AM
Idle problems on warm day. pigdog Mechanical / Help 1 05-02-2003 09:53 PM
