oil leak - Yamaha R1 Forum: YZF-R1 Forums
 2Likes
  • 1 Post By Anubis
  • 1 Post By Aint_too_ghetto
post #1 of 5 (permalink) Old 04-01-2019, 06:16 PM Thread Starter
oil leak
I have a 2003 r1 that has a oil leak coming from item # 32 on the diagram.My question is what goes inside item #32 oil or coolant?because i taught it was coolant.
Thanks in advance!!!
memincars is offline
post #2 of 5 (permalink) Old 04-02-2019, 08:14 AM
Wishin' I Was Fishin'
Anubis's Avatar
Are you 100% sure that the oil is coming from there and not trickling down from somewhere else? There should not be oil coming out of there, that's the water jacket joint.
memincars likes this.
-Sgt. Fernando Padilla-Ramirez *KIA* March 28, 2003
-Michael James Johnson August 12, 2003 1:18 AM R.I.P.
Keep Calm and Chive On
Anubis is offline
post #3 of 5 (permalink) Old 04-02-2019, 08:42 AM Thread Starter
Thanks for the reply Anubis! that is exactly what i am trying to find out because the oil leak look like is coming from that general area.My next guess will be that metalic box (air induction syst) with oil dripping but i think is air going thru that.If anyone one can confirm will be great.I am running out of ideas!!!
post #4 of 5 (permalink) Old 04-02-2019, 12:57 PM
Wipe it down splash some baby powder in the area. See the exact source.
Aint_too_ghetto is offline
post #5 of 5 (permalink) Old 04-02-2019, 04:27 PM Thread Starter
I will try that next, now that everything is apart.Hopefully is something easy but i doubt it because the spot where is at is really tight.Thanks for the baby powder idea!
Water/Oil Pump Seal Loose Causing Oil Leak wwholden 04-06 R1 Mechanical Help 0 08-31-2016 04:47 PM
Please help, Small oil leak from hole in oil pan OnPointR1 07-08 R1 Mechanical Help 17 07-12-2015 11:21 AM
06 R1 fairing bolt on oil pan caused oil leak Graverunner 04-06 R1 Mechanical Help 9 06-10-2013 11:49 AM
Small oil leak from center of oil pan (rear) sucram1 04-06 R1 Mechanical Help 9 02-13-2011 09:42 AM
leak coming from middle of oil pan, dealer said oil pan, then now waterpump weep hole Gant 04-06 R1 Mechanical Help 13 07-04-2010 04:57 PM
