Another "wont start after winter" thread - Yamaha R1 Forum: YZF-R1 Forums
post #1 of 4 (permalink) Old 06-12-2019, 02:16 PM Thread Starter
New England winter/spring is so brutal for maintenance.
I'm new to wrenching but committed to doing absolutely everything myself that doesnt require extensive costs, expertise, and specialized equipment. Got a master cylinder rebuilt, new stator, aftermarket exhaust, PC-V, and brake job under my belt so far.
To the point... the bike didnt start after winter. It would crank strongly but not fire. I could get at least 5 good cranks out of it before it started to take a toll on the battery.
Now, I reconnected that PCV ground wire so many of us seem to forget about. The bike cranks AND fires/runs but immediately stops when I let go of the starter button.
Right now I'm thinking my next move is to reflash the PC-V seeing that the starting issue directly involves the PC. (Meanwhile... dash lights, fuel pump primes, starter relay clicks, bike cranks, runs with starter depressed. I have "just for fun" replaced the spark plugs with new ones. Replaced the starter relay with a DB Electrical relay they identified as the correct part of this year/model/make. I have a new lithium-ferrous battery coming along with a replacement fuel pump relay)
There are 7 diagnostic codes stored but I dont know when they were last cleared. I'll clear those tonight I just didnt have time and patience at 8pm. The stored codes are: 11, 12, 16, 17, 19, 22, 30.
Any thoughts before I come back with new codes or re-flash the PC?
bthekahuna is offline
post #2 of 4 (permalink) Old 06-13-2019, 06:03 AM Thread Starter
diag 62 > key ON > starter switch to "ON" > flick starter switch to OFF then back on > turn key to OFF
I followed that per manual and it doesnt reset the codes, so they are all current then?
Chances of bad stock ECU?
Chances of bad PCV? (bought at end of 2018 season)
Ignition system isnt grounded properly?
Bad starter switch assembly?
Thoughts on those, or elsewhere?
post #3 of 4 (permalink) Old 06-14-2019, 08:44 AM Thread Starter
hmm. not getting any bites on this. Wondering now if I should have used a title that will get someones attention that doesnt specfically monitor THIS mechanical help page.
I'm going to disassemble the start switch assembly on the handlebar this weekend and see if there's a short. Then going to check the bike's grounding. From there Ill pick up a multimeter and start checking all the connectors/sensors/relays.
Anyone out there?
Riding in RI-CT-MA area. Lucky 13.
post #4 of 4 (permalink) Old 06-21-2019, 05:55 AM Thread Starter
UPDATE
in case anyone actually reads this
Like planned I opened up, cleaned and rebuilt the starter/kill switch. It was a little 'muddy' on the contacts but the cleaning was not the solution I was hoping for. But it eliminated one more variable.
Checked continuity of main ground wire from battery to frame. No problems.
Took another look at the starter relay and it finally occurred to me that if the terminal poles are reversed from stock, then the wiring harness leading in would have to be reversed as well, but it only has one fitment and the leads are locked in permanently. I went back to my stock relay but it wouldnt fire so I definitely think the original was toast. I ordered a factory OEM relay that I have on hand now and Ill update if it turns out to be the fix after all.
By the way the non-spec relay I used was from DB Electrical. It does NOT work on 02-03 R1. I emailed them and asked them to take this bike off the fitment list. Hopefully they comply or remedy in some fashion.
neutral light wont come on when in neutral and wont start with kick stand down whitey601 00-01 R1 Mechanical Help 17 08-28-2018 05:27 PM
Wont start when hot.. bogs out alot in first..wont idle normal ): eoszlak 98-99 R1 Mechanical Help 56 09-20-2012 12:53 PM
Winter projects bring Summer enjoyment!! here is the start to my winter moneypit!! 02R11986 Appearance & Mods 2 10-06-2011 11:02 AM
Another "09 R1 won't start" thread. BigJonR1 09-14 R1 Mechanical Help 11 03-15-2011 08:29 AM
R1 Before Winter / After Winter pics Tezzmin Appearance & Mods 26 03-29-2010 07:29 PM
