Error Code 18- EXUP valve problem help - Yamaha R1 Forum: YZF-R1 Forums
post #1 of 16 (permalink) Old 04-18-2009, 03:33 AM Thread Starter
R1 wishful thinker :(
saki302's Avatar
Hi Guys!
I was running a Samanna servo sub for th ebetter part of a year- recently, the code 18 error (EXUP stuck) popped up. I reinstalled the servo motor (removed the sub), and the code went away- for like a day.
Now it's back- the servo motor bench tests fine (resistance in spec, turns when 12V is applied). I think I am not getting power from the ECU to the servo sub. Wiring harness looks fine, and I double checked the areas where I re-soldered the OEM plug- they test fine on my multimeter, and are wired properly.
Can anyone help with this issue? The CEL is driving me batty!
I went through the #53 diagnostic procedure already- servo motor does not spin when you flip the kill switch. The (new) samanna servo sub I got does show change on the dash on procedure 53, but code 18 stays on,
A huge thanks in advance if anyone has any ideas on what to try next...
-Dave
saki302 is offline
post #2 of 16 (permalink) Old 02-06-2010, 08:39 AM
Moto-Psychos's Avatar
i see noone answered to this. FYI yamaha did a product update on that servo valve spring becuase it was getting stuck take it to the dealer and tell them to look for the update bulletin and get the right part in it for you
Moto-Psychos is offline
post #3 of 16 (permalink) Old 02-07-2010, 06:05 AM
Swatskeb's Avatar
Sounds like the servo sub may be jacked. You might give the graves servo sub a try if you havent removed the stock connector.
Swatskeb is offline
post #4 of 16 (permalink) Old 03-11-2010, 01:22 PM
I just recently got code 18 with my Graves servo sub too..
Wild Earp is offline
post #5 of 16 (permalink) Old 03-11-2010, 02:05 PM
One fast Jew!!!
voodoo34's Avatar
pull pin #3, there is a thread on it, with pics.
04 Anniv R1???
voodoo34 is offline
post #6 of 16 (permalink) Old 03-11-2010, 08:14 PM
Strait roads sucks!
R1 Who's Avatar
Link to thread? Please.
R1 Who is offline
post #7 of 16 (permalink) Old 03-11-2010, 08:17 PM
shoeaholic's Avatar
shoeaholic is offline
post #8 of 16 (permalink) Old 03-12-2010, 07:19 AM
Strait roads sucks!
R1 Who's Avatar
Thank you.
R1 Who is offline
post #9 of 16 (permalink) Old 05-16-2011, 10:16 PM
I have a 2003 r1 code 17 and 18 on with check engine light bought the brazzers exup eliminator plug it in too the hanging wire code 17 is off but 18 is still on. How do I take off or disconnect the exup servo motor?
Carmody is offline
post #10 of 16 (permalink) Old 05-17-2011, 06:07 AM
My R1 eats everything
With my Bazzaz servo eliminator I still get a code 18 also. It came on the first time I started the bike after removing the exup and has never gone off. I'm thinking of either trying the remove pin #3 mod or putting it back on.
2008 R1 (Red)
Bazzaz Z-Fi with Z-AFM, EXUP Servo Eliminater, Gaves SMOG Block offs, Yoshi TRC Carbon Pipes, Leo Y-Pipe, -1 Front Sprocket, Speedohealer, Flush mounted turn signals, Integrated Tail Light, Fender eliminator, Frame sliders, Throttlemeister Bar ends, Swingarm sliders, Tinted windscreen, Bodylights, HID High and Low beams 35W 6000k, LED marker lights
Dyno Results
[email protected] 77.0ft-lbs @9043rpm
R1-016 'Venom' Squadron
johns191 is offline
post #11 of 16 (permalink) Old 05-17-2011, 05:46 PM
What does removing pin #3 do and how do you do it?
Carmody is offline
post #12 of 16 (permalink) Old 06-02-2011, 07:24 PM
SQUIDS SUCK
ROSWALD21's Avatar
Send a message via Yahoo to ROSWALD21
Hey guys im having trouble finding a picture of this so called pin #3 any help, thanks
ROSWALD21 is offline
post #13 of 16 (permalink) Old 05-25-2013, 06:02 PM
R1Ryder260's Avatar
I have this problem now... Just purchased the bike so I don't understand they must of reset it? I put 475 miles on it and this just happened other day. Looks as if I already have the Servo Eliminator. Which is pin#3? Does everybody pull that pin?
R1Ryder260 is offline
post #14 of 16 (permalink) Old 05-25-2013, 07:40 PM
R1Ryder260's Avatar
Update: Fixed! Pulled pin#3! Road 30miles just now and no light!!!
post #15 of 16 (permalink) Old 06-22-2015, 09:07 PM
Which 1 is the pin no 3?
TBM30 is offline
post #16 of 16 (permalink) Old 06-23-2015, 10:45 AM
Hi im newbie here
Can anybody help me?
Which one is the no 3 pin have to pull out?
TBM30 is offline
Closed Thread
00 EXUP error code jmy2kR1 Mechanical / Help 3 07-14-2006 02:44 AM
'98 Exup valve error r1mixup Mechanical / Help 4 04-10-2006 06:01 PM
EXUP valve and error light jimmyp How To's 2 04-29-2004 08:03 AM
EXUP valve and Error Code on 04 R1 jimmyp Mechanical / Help 3 04-23-2004 10:16 AM
EXUP valve and Error Code jimmyp Appearance & Mods 2 04-22-2004 08:23 PM
