06 R1 weird noise - Yamaha R1 Forum: YZF-R1 Forums
post #1 of 7 (permalink) Old 02-25-2019, 01:26 AM Thread Starter
06 R1 weird noise
Hi, recently brought an 06 R1, Everything seem fine with it. However, when riding it at 1-2 mph it makes a weird cunkling noise. It just isn't smooth, feels oddly off. Is this normal? everything is smooth and fine after 10 mph.
Aint_too_ghetto is offline
post #2 of 7 (permalink) Old 02-25-2019, 06:45 AM
04
not normal. chain ok ,, lubed, look at sprockets ,, wheel lined up and secure gravel stuck in tire ? or screw
tory ii is offline
post #3 of 7 (permalink) Old 02-25-2019, 05:33 PM
Doppler's Avatar
I'd say it is normal for the bike to be a bit clunky at 1 - 2 MPH considering you could barely have the clutch engaged at that speed. It's designed to be smooth at 100 times that speed.
Doppler is offline
post #4 of 7 (permalink) Old 02-27-2019, 11:28 AM Thread Starter
Chain was a bit loose, it's now adjusted and lubed. But i still feel it's like coming from the engine. I want to even say it clunks more when i'm riding slow cold, goes away a little bit when it warms up. Anyways, nothing too extreme, Valve adjustment maintenance coming up in about 4k. I'll see if it smooths out after.
Hey, feels normal when i'm going fast right. Just don't ride slow there won't be no problems lol thanks for yall's input
post #5 of 7 (permalink) Old 02-28-2019, 09:38 AM
Deer_killer's Avatar
Most likely coming from the clutch. Especially since it improves when it gets warmer. Mine has a subtle chatter when cold. Clutch is also really grabby when cold. Smooths out when everything is warm (also have an 06). Is it really noticeable or are you maybe just looking for a problem where there isnít one? No insult. Just the way I am sometimes...
Deer_killer is offline
post #6 of 7 (permalink) Old 02-28-2019, 09:43 AM
andrewstclair's Avatar
in first gear with he clutch out and it idling it should be about 12 mph. anything below 15-16mph would be a bit lurch and clunky because of the surging of the engine. a slight bit of throttle applied and it should smoothe it out. that can be helped a bit with a tuneup, valve adjustment and sync.
09 R1 black/gold SOLD
2015 R1M 007
2016 R1 Track
andrewstclair is offline
post #7 of 7 (permalink) Old 02-28-2019, 05:14 PM Thread Starter
Subtle chatter sounds about right. I wasn't looking for a problem, it came to my attention last week trying to creep out the drive-way completely cold real slow to not wake the neighbors. Sounded like something in the front slapping my front fender with each wheel turn, had to stop to check the front wheel. I since couldn't replicate those real noticeable thuds anymore since i let my bike warm up.
This sound logical. It's probably nothing wrong, although i just found out yesterday one of the headers pipe is dented and has a pen tip hole in it. Might be the reason the engine running weird. About to change new headers and see how it goes from there.
02 r1 weird ass rattle noise...(with sum bike pics!) biggles 02-03 R1 Mechanical Help 24 09-12-2017 06:16 PM
06 Weird Clutch Noise? ambitionist 04-06 R1 Mechanical Help 5 05-01-2015 08:03 AM
05 R1 HELP! Weird Noise (Video included) Jstilly85 04-06 R1 Mechanical Help 3 10-03-2011 12:22 AM
08 R1 weird noise?? Joseph.ramirez6 07-08 R1 Mechanical Help 2 08-28-2011 01:45 PM
07 R1 Weird Noise (Video Included) JRich Mechanical / Help 4 09-05-2010 08:06 PM
