Bike idles fine then dies when rolled - Yamaha R1 Forum: YZF-R1 Forums
  • 1 Post By Stormd17
post #1 of 3 (permalink) Old 05-15-2019, 11:45 AM Thread Starter
Hey guys as the title says, I was having problems with my bike staying charged. Did a full electrical test and found my stator to be the issue. I replaced the stator and rectifier both as a piece of mind. Just got the new stator put on this morning, new gasket, and everything bolted back up. Threw the gas tank back on and started the bike. It idled great for about 10 mins. Charge held good, when I went to roll it out of the garage I kicked the kickstand up and it acted like it was gonna die. Got it rolled back more and it died. Started it back up and went to roll it again and it died again. Put it back in the garage and started it back up and it seemed a little sluggish on start but it started and was idling just fine got on it again went to roll it forward and it died immediately. This is happening in nuetral and in gear. It will idle perfectly fine in nuetral and in gear tho. The second I move it forward or back it dies. What could be the problem? I hasn't having any of these issues before I replaced the stator.
Stormd17 is offline
post #2 of 3 (permalink) Old 05-15-2019, 12:41 PM
Aikuken's Avatar
Had a case close to this. The throttle had been damaged cos the battery was connected backwards at some point (Don't know how the usual protections didnt prevent it).
Also check for a pinched fuel line under the tank.
Sent from my SM-A305F using Tapatalk
Aikuken is online now
post #3 of 3 (permalink) Old 05-15-2019, 02:10 PM Thread Starter
Okay well the bike was running fine before the stator replacement just wouldn't stay charged and I've only disconnected the positive cable on the bike therefore they have never been criss crossed. I will look into the pinched line. Could be possible
milheim05 likes this.
Stormd17 is offline
15 R1 idles then dies? JonRose 15-19 R1 Mechanical Help 7 11-18-2018 07:50 AM
'99 R1 idles. Sort of. Then dies. Belgarion 98-99 R1 Mechanical Help 29 05-29-2013 08:58 AM
09 R1 Idles fine till fan kicks on. Takachnp 09-14 R1 Mechanical Help 12 04-11-2013 12:22 PM
05 R1; Idles low then dies at stops. TPS already changed barbeddragon General Motorcycle Discussions 22 11-12-2011 06:20 PM
07 Idles Perfectly for 10 Seconds, then dies... nix07r1 07-08 R1 Mechanical Help 18 05-10-2011 06:11 AM
