04-06 R1 Go Kart - Yamaha R1 Forum: YZF-R1 Forums
post #1 of 24 (permalink) Old 06-15-2019, 07:39 PM Thread Starter
04-06 R1 Go Kart
Hey everyone I'm new to this forum but I have some questions I'm a 16 year old kid who is currently in the process of building a gokart with an r1 engine I have acquired for only $450 with $500 worth of extras the guy threw in, one of them being a power commander. Anyways i know there is alot of switches and shit I'm gonna have to bypass as I won't be putting this back in a bike. Can anyone tell me everything I'm gonna need to bypass inorder to get the bike to turn over / start.
Sent from my SM-G965U using Tapatalk
Andrew_S is offline
post #2 of 24 (permalink) Old 06-16-2019, 07:57 PM
Doppler's Avatar
Hi mate, welcome to the forum. Pretty cool project, especially considering your age. Before you get too into it I trust you are aware that the R1 motor produces significant power especially for a go kart and some of the engineering will not be straight forward as you may think.
Anyway, enough sensible! First question is what have you actually got? Is it a bare motor or do you have a wiring harness as well? If you don't you will need one. Do you have an ECU, radiator and fans, instrument panel, air box and throttle bodies, exhaust headers, other sensors like tip over switch?
If you have the motor from throttle bodies to exhaust as well as a harness and ECU you will be close to at least getting it to run.
Plenty of parts around for that generation so you should be able to get what you don't have without huge $$$'s Maybe add some photos of what you have.
Doppler is offline
post #3 of 24 (permalink) Old 06-16-2019, 08:22 PM Thread Starter
Hey so yea I'm very aware this is gonna be alot more advanced then let's say a lawn mower engine but I'm ready for the challenge. Anyways so yea I have the complete engine with ecu harness power commander exaust manifold airbox spare parts like extra sprockets and throttle bodies with extra Injectors in them. I don't have the start stop switch or the key ignition switch I did order them both off eBay and in the mean time I did short the ignition wires and for the throttle bodies to calibrate and the cluster to turn on but the light on the power commander didn't turn on so I'm pretty sure the ecu didn't have power. And I'm sure it's because I still have multiple switches to bypass like the clutch switch and the kick stand switch and saftey switches before it will give me spark but I can't find much info online about what I'm trying to accomplish so I came here to ask fellow R1 people about all the wiring I need to bypass to get it to run pretty much and any other things you guys think I should know as I'm not exactly a veteran R1 mechanic.
Andrew_S is offline
post #4 of 24 (permalink) Old 06-16-2019, 08:22 PM Thread Starter
Here are some pictures of what I'm working with
Andrew_S is offline
post #5 of 24 (permalink) Old 06-17-2019, 08:29 PM
Doppler's Avatar
Just checking you are in the US right? Reason is if you have a euro model bike it has an immobiliser and without the key that's paired to the ECU you wont get it to run.
To get the thing going remove the power commander and reinstall it once its running to remove at least one variable. Sounds like you are on the right track considering the sensors/switches. Off the top of my head, one's not on the actual motor include as you said, clutch switch, stand switch (there's a special relay for these that also connects to the neutral switch), tip over switch, air temp sensor (I think it's in the air box on that generation), O2 in exhaust (Maybe not on US model), water temp. Most of the others are on the actual motor and inlet.
Doppler is offline
post #6 of 24 (permalink) Old 06-18-2019, 02:50 AM Thread Starter
Yes I have a us engine so there is no imobilizer but the mail came today and I got the starter switch and I plugged the battery back in and I have the tip over sensor plugged in and when I turn the switch to the on position the cluster turns on and the throttle body calibrates and the power commander light turns on but when I go to crank it over there's no spark. How would I go about bypassing the other sensors and where would the connector be? I feel like my harness is Missing some places a Connector should be but idk
Andrew_S is offline
post #7 of 24 (permalink) Old 06-18-2019, 04:43 PM
andrewstclair's Avatar
put your volt meter to continuity and check if when the kick stand is "up" if the switch is open or close and bypass it accordingly. do the same for the tip over switch when its pointing the right way. the clutch switch you may want to make functional. some bikes have a rev limit thats lower with the clutch lever in i can't remember if that year is one of them, but i don't think so. you want the sensor not he top of the valve cover plugged in for it to spark and theres another plug near it that is green or something that can accidentally be swapped. go to the mechanical help section and at the top is a stick with the service manuals, download yours and lookup component locations for the sensors and it should give you an idea where on the harness they are connecting. there will be photos of plugs and a lot of useful info that other people aren't going to be able to explain as well as a photo
09 R1 black/gold SOLD
2015 R1M 007
2016 R1 Track
andrewstclair is offline
post #8 of 24 (permalink) Old 06-18-2019, 07:16 PM Thread Starter
Does anyone know what these connectors are?
Andrew_S is offline
post #9 of 24 (permalink) Old 06-18-2019, 07:23 PM
Black one looks like fans. The green and white one go around the airbox. If you look at the wire colors and look in the service manual it will make it easier to be certain since quite a few of the plugs are identical
iamzombie likes this.
2015 R1M 007
2016 R1 Track
post #10 of 24 (permalink) Old 06-26-2019, 04:28 PM Thread Starter
Does anyone know all the switches and sensors needed for spark? So far I have the kickstand switch bypassed and I don't get spark but the power commander turns on
Andrew_S is offline
post #11 of 24 (permalink) Old 06-26-2019, 06:53 PM
You need an 04 service manual. Wiring diagram and Section 8-16 to 8-20 to trouble shoot.
How do I know...I built this with an R1 motor:
https://www.lotustalk.com/forums/f68...-tr1ke-465332/
Also - the green and white plugs are for the fuel pump / tank level sending unit. The brown plug is the rear brake light.
ID:	1000075   Click image for larger version
ID:	1000077   Click image for larger version
dspecgsx is offline
post #12 of 24 (permalink) Old 06-26-2019, 07:24 PM Thread Starter
Thanks for telling me what those connectors were for and yea I have the service manual but seeing wiring diagrams confuse the shit out of me but nice build that thing is seriously sick. The one I'm building is gonna be for the dunes out here in Oregon
Andrew_S is offline
post #13 of 24 (permalink) Old 06-26-2019, 07:41 PM Thread Starter
Success!! I finally got spark. Idk what I did but it has spark now.
Andrew_S is offline
post #14 of 24 (permalink) Old 06-26-2019, 10:05 PM Thread Starter
Just got it to run by pouring a bit of gas down each intake manifold, thanks for everyone's help
Andrew_S is offline
post #15 of 24 (permalink) Old 06-27-2019, 07:42 AM
para bellum
Kangaroo's Avatar
:headshake:
This reminds me of the old thread, "Should I get an R1 as a first bike?"
Read the wiring diagram on the service manual. Stare at it long enough and it'll make sense at least in identifying the connectors. The manual will show you the starting circuit to crank the motor. Here on the forum you can search for most of the connectors and setup to get the bike going.
Brothers riding on...
Bandrews 10/11
Dieyoung69 11/10
Vman1300 3/09
Gawarrior 6/08
Elviswarrior 6/07
Crazyclimbr 3/07
K_flexxx 6/06
Kangaroo is offline
post #16 of 24 (permalink) Old 06-28-2019, 01:30 PM Thread Starter
Originally Posted by Kangaroo View Post
:headshake:
Next step is to figure out how to mount this into my gokart frame
Andrew_S is offline
post #17 of 24 (permalink) Old 06-30-2019, 08:42 PM Thread Starter
How much hp you guys think an 05 r1 can handle? After I get done building the gokart I'm thinking of turboing it trying to make 200whp. Engine has 27k miles
Andrew_S is offline
post #18 of 24 (permalink) Old 07-01-2019, 03:34 AM
You should be asking yourself how my HP do you think your frame can handle? Mine can barely handle the HP of the stock motor. Can't keep the rear wheel on the ground for the first 3 gears. At 150 mph the whole front end is skating around like its on ice.
dspecgsx is offline
post #19 of 24 (permalink) Old 07-01-2019, 03:49 AM Thread Starter
Well... I did stretch my frame using a harbor freight welder so I honestly don't know if it can even handle 40hp but we will find out and the front end won't be on the ground much as it's for the dunes so it's gonna be constantly wheeling
Andrew_S is offline
post #20 of 24 (permalink) Old 07-01-2019, 01:41 PM Thread Starter
Actually quick question if I unplug the power commander will the bike still run? Like will the stock ecu control it or is there a stock fuel injection system that plugs into where the power commander plugs in. I've seen videos where you have to splice a wire into your ecu when installing the power commander but mine has 2 big plugs that plug into the harness and that's it
Andrew_S is offline
Gixxer kart? Pffft... Has nothing on the r1 kart roki530i Off Topic Talk 1 06-26-2007 10:13 PM
Go!habs Go! Go!habs Go! (keep political BS out of it) martinc Off Topic Talk 40 04-21-2004 09:40 PM
Does anyone Go-kart??? boomhauer General Motorcycle Discussions 6 11-20-2003 10:59 AM
go-kart day's in brisbane Aus. MadDan Local Meets & Events 0 09-23-2003 07:37 PM
R1 Go-Kart fordy Mechanical / Help 31 03-31-2003 07:45 AM
