Help removing Clutch bearing - Yamaha R1 Forum: YZF-R1 Forums
post #1 of 2 (permalink) Old 06-25-2019, 06:05 PM Thread Starter
Do you guys have any idea to remove this? Will hammering it out be okay?
RJayY is offline
post #2 of 2 (permalink) Old 06-26-2019, 06:54 AM
milheim05's Avatar
A hydraulic press is a better option, but if you're careful then hammering it is the other way to go. You should also get a slide hammer with a bearing puller.
milheim05 is offline
main bearing color chart and rod bearing chart snapperhead069 04-06 R1 Mechanical Help 0 03-19-2013 06:54 PM
Help removing bearing in water/oil pump bob123123 00-01 R1 Mechanical Help 1 01-29-2013 08:56 AM
Need rod bearing advise; Second time rod bearing spins Roba101 07-08 R1 Mechanical Help 36 09-16-2011 03:12 AM
Removing countershaft sprocket without removing chain? DonJigweed 07-08 R1 Mechanical Help 9 08-03-2009 12:31 PM
Removing Throttle Cable - Empty tank before removing? Brownie433 Mechanical / Help 4 04-27-2004 12:22 PM
