07 Coolant leak... - Yamaha R1 Forum: YZF-R1 Forums
  • 1 Post By Torqui
post #1 of 2 (permalink) Old 05-28-2019, 03:54 PM Thread Starter
07 Coolant leak...
I was stopped at a light when I noticed a blue-ish liquid pooling under my bike. I got it back home and figured its a coolant leak. I pulled the tank off and check the thermostat housing & hoses and im pretty sure I found my problem. There was visible resin from the coolant on the seal of the thermostat housing as well as around the hose clamps.
I have 2 questions I could use help with:
1. There is resin around the hose clamps as well as thermostat housing--is there a smart way to see if an individual piece is failing vs replacing all of the hoses/clamps/housing at once?
2. I had my ECU flashed by SuperBikes Unlimited and have the temp fans come on a little sooner than factory settings. I ride in Florida so my thought was to keep the bike cooler when I get stuck in traffic. Does this have any negative effects for my thermostat or cooling system?
Forgive me, I am sort of a newbie when it comes to motors. I try to read forums and reviews to educate myself on the issue but I figured I would ask for some guidance here.
Thanks!
ID:	999159   Click image for larger version
nmbox is offline
post #2 of 2 (permalink) Old 06-03-2019, 07:01 PM
I would just keep the tank up and start the bike and see if you can spot the leak. Clean it up before you do it so you can see easier. I'm curious what temp did your bike idle at before the flash, and what does it idle at now? Also I don't think the flash has anything to do with the leak.
Humza likes this.
Torqui is offline
07 coolant leak :( SdsuLax11 07-08 R1 Mechanical Help 3 05-13-2015 07:35 AM
coolant leak out of 2001 R1 2001RWON 00-01 R1 Mechanical Help 13 01-19-2013 10:59 AM
coolant leak 2000 r1 ham_r1 Mechanical / Help 7 01-26-2004 06:20 PM
Coolant Leak! VinR1 Mechanical / Help 12 06-10-2003 12:22 AM
coolant leak champions#442 Mechanical / Help 5 08-01-2002 02:18 PM
