I assume you solved this, but I had a similar issue and it was a bad connection between the pins in the headlight sub harness connector, red/yellow I believe, it was the one of the corner pins of the plug. You may see some yellowing of the connector from the heat due to high resistance. Clean or replace the contacts.
