Was speaking to Hansdyno today and he asked me if I had received the bulletin from Yamaha about removing the passenger pegs. I told him I hadn't so he proceeded to tell me that Yamaha Germany had sent him a notice that if you remove the passenger pegs, you have to install some type of a bar back in the same space were the peg mounts were. Failure to do so could result in the subframe cracking and/or breaking. They are using the pegs and that cross member between them as part of the reinforcement for the whole unit. Since the undertail is not smooth, I just cut the pegs off and have the base left. I will have this powdercoated black and then remount it.
I'm guessing that it has something to do with a bike that is designed originally for the track and then for "The Consumer Sales" they got to put on the pegs etc. Thus creating somewhat of a glitch :dunno
Did you by any chance see the bulletin or memo? I have been trying to find one so we can actually read it but no luck so far. Sounds like you read something about it. Thanks.
I talked to my Yama dealer yesterday when I ordered my 09 and they have not heard of this...My wife works at a shop where they are going to fab a new bracket. I get mine on Thursday...
You have to unplug the wiring harness, remove the battery, and then remove the battery tray that it sits in. It isn't too difficult and only took me an hour or so.
Just keep in mind that the person that this came from doesn't ride in the street. They run a very successful roadracing team in Europe. Looking at the subframe alone you could see a worry for twisting problems without the brace, but there's really no telling. I guess time will tell.
Definitly not questioning anything you have said and I should have clarified one thing. I am running the track with this one and definitly plan on checking the bike over after every race/track day.
I took mine off and there is no way that the rear pegs are going to effect anything with the rear sub frame. Thats my opinion of course but it just takes 30 minutes to take it apart and you will see for yourself. Really cleans up the the ass end :thumbup
Ha, yea right. When I figured I had a small problem, it gave me an idea for my tag. I fabricated two flat brackets, used the black bolts from my heat sheilds and made them about 1 1/2inches longer than I needed. Bent the extra for my tag. Spray painted them black and killed two birds with one stone It was pretty easy. I just got a 15cc rear brake reservoir and fabed a bracket to mount behind the heel guard. I will post some pics tomorrow if I can get sometime.....:thumbup
You have enough clearance for the tire there?
I like those "Credit-Card" license plates
However I am not sure if a flat sheet is doing what this "link" is meant to do.
Looking at the original part, this thing is designed not only to act as a spacer but more so to withstand bending (what the sheet metal won't).
I suspect this link is meant to counteract torsion of the subframe...
I have two more weeks to wait until I can check it out on mine...:rant
I took it out last night and ran it through the gammit, hard braking wheelies pot holes no issues with the plate hitting the tire or rear hugger.
As far as the subframe not being strong enough, I say its alot of crap. When you get your bike ( soon ) i hope you will see its not a big deal but to each his own. Unless maybe your going to be putting a 100lb weight in your storage area under the rear seat cowl LOL
The brace looks to me to be there to stop the rear footpegs from folding inwards under rider weight. Not so much for support of the rear sub-frame itself. Of course I don't have my 09 yet :rant so can't make more than an alternative suggestion for you all...:nopity:
What he said. Thats the only reason I can see. Its a moot point, you are not going to have a rear passenger, so take them off and enjoy the clean ass end of your bike and forget about it.........
to cover their asses just in case probably..... this way they can say that they have issued a bulletin so they aren't liable if someone removes it and something breaks
That statement doesn't make any sense at all. If it was for fat chicks, it wouldn't be needed (as per the Yamaha buletin) when the pegs are removed, right?
Why seem 50% of the people here all the time think that tech buletins and instructions all are conspiracy?
- the brace warning just to cover ass
- break-in instructions to steal hp
etc..
And even more striking: How can one say "it's not needed" without having a clue on the static loads in that subframe. Have you done a computer analysis and know?????
