2012 Yamaha R1 not starting when too hot - Yamaha R1 Forum: YZF-R1 Forums
post #1 of 7 (permalink) Old 03-26-2016, 05:27 PM Thread Starter
Yellow jacket
Spidymonkee's Avatar
Hey guys. I have a 2012 R1 Raven that has 8000 miles on the bike that I have a question about. When I start the bike from being cold it starts fine. But if I ride thru town and the bike is around 224 ( when the fan kicks on) temp when I turn it off and try to start it back when it is around that temp after sitting it will not start. It tries but it just ends up killing the battery and I have to roll it off. Is there some safety feature I don't know of where it will not start when too hot? I could leave it running until the fan cools it off. Thanks.
Spidymonkee is offline
post #2 of 7 (permalink) Old 03-29-2016, 06:13 AM
love my R1
ThatOneGuysR1's Avatar
i have a 09 and it never over heats and only gets too 200 if im sitting still for a minute but there has been times i have turned it off and two minutes later it wouldnt start like the batttery had no juice touch some jumper cables too it and instantly it starts idk what is causing it i would live to find out
love my r1
ThatOneGuysR1 is offline
post #3 of 7 (permalink) Old 03-29-2016, 08:00 PM
You might be getting vapor lock... basically the fuel could be turning from a liquid into a gas due to the extreme heat which can cause the bike to not start after the heat soaks through to the fuel. Insulated fuel lines might help prevent this (assuming it's the cause).
Have you ever tried priming the fuel pump a few times in a row before cranking the bike when it won't start?
-2013 Yamaha R1 Rapid Red
-2012 Yamaha R1 50th Aniv. Edition, (RIP 11-25-2018)
-2007 Suzuki SV1000S
partyman66 is offline
post #4 of 7 (permalink) Old 04-17-2016, 03:46 PM
My R1 will break the bank
I'm having the same problem. Let the bike cool and it will crank again
IjustRide is offline
post #5 of 7 (permalink) Old 04-18-2016, 07:09 AM
Get your battery tested. Check the charging system, Check your fuel pressure before and after the no start issue.
YamahaGoldTech is offline
post #6 of 7 (permalink) Old 04-22-2016, 12:03 PM
love my R1
brand new battery and pcv but the dealer said it is the starter but for now as long as i let it get down to 180 it will fire so im in the market for a new starter
love my r1
post #7 of 7 (permalink) Old 04-22-2016, 12:47 PM
GodofDe4th
You're running a PCV? Run it on a zero map and see if it does it.
68mustang is offline
