2009 R1 clutch - Yamaha R1 Forum: YZF-R1 Forums
post #1 of 5 (permalink) Old 10-07-2017, 08:25 PM Thread Starter
2009 R1 clutch
Gentleman I had se weird sounds coming from the clutch when Inwas starting from a stop light. Took the clutch apart and results were not satisfying, any and all information would help.
Lots of heat, corosion?
What clutch kit should I get?
ID:	956185   Click image for larger version
ID:	956193   Click image for larger version
Jakoubek44 is offline
post #2 of 5 (permalink) Old 10-08-2017, 01:51 PM
NoExpert's Avatar
OEM and add in a couple parts from a 2008, specifically the last fiber plate, spring and seat. It’ll smooth out the clutch. Even on my 2014 with only 5000 miles my steels had some burn marks, and I’m pretty easy on it.
NoExpert is offline
post #3 of 5 (permalink) Old 10-08-2017, 04:58 PM
“Rhinestone Cowboy” MF Doom
DarkHorse's Avatar
Stock
DarkHorse is offline
post #4 of 5 (permalink) Old 11-10-2017, 11:15 AM
BlueYama1's Avatar
That's my suggestion, OEM clutches seem to be built very well. That will probably be my next mod.
BlueYama1 is offline
post #5 of 5 (permalink) Old 11-10-2017, 12:25 PM
APO2112's Avatar
EBC has a decent kit with upgraded springs like the YEC springs. I have a set of their clutch disks but have yet to try them. Graves clutch mod like @NoExpert indicated is a must.
“If you are always pushing at the limit you get a better feeling with the bike and give better information to the mechanics,” he says. “If I crashed 27 times, I was very close to crashing maybe 50 times! That gives me a feeling with the bike – you understand many things, what crashes you can save and so on.”-MM93
APO2112 is offline
