2011 r1 died and won’t start - Yamaha R1 Forum: YZF-R1 Forums
  • 1 Post By Sabotage
post #1 of 7 (permalink) Old 05-26-2019, 08:22 AM Thread Starter
Hello I am new to this forum hoping someone can help me. I was riding for about an hour and everything was normal, until the bike died. Pulled over and when I would try to start it no starter and cel light would blink. So then I thought my battery was dead as it has been a little weak. Put another batter hooked up with jumper cables and seemed like it had enough juice but still no start. Please help. Can hear fuel pump priming but it’s not cranking over
Bobby S is offline
post #2 of 7 (permalink) Old 05-26-2019, 09:18 AM
My R1 go to warp drive
Sabotage's Avatar
The cross plane needs a lot of power to start. Once, my battery died and i tried to jump it off my car battery and wouldn't. For whatever reason, crappy jumper cable or car battery, it still wouldnt start. Purchased a brand new good battery and it's been fine since. Some concerns though, if the bike was running and just died, i would check the whole charging system. The bike should not die even with a weak battery unless the battery is shorting or something...
Bobby S likes this.
PCV tuned, Bazzaz QS, Air box mod, BMC Filter, Block off plates, Flashed ECU, -1 Front Sprocket, SpeedoDRD, Spiegler Lines, EBC Extreme Pro pads, Braking SK Rotors, Q3's, Leo Vince Carbon Fiber slip-on W/ Y-Pipe, Black and Gold Euro conversion, 10,000k HID, Brembo MC and clutch perch, Smoke Puig Windscreen, Shogun Frame Sliders, Signal mirrors, Harris rearset, Techtronic auto blipper, EK 3D 520 chain conversion, Ohlins 30mm ctrg & TTX shock, Lightech chain adjuster, CF sbk hugger, TI bolts kit
Sabotage is offline
post #3 of 7 (permalink) Old 05-26-2019, 11:10 AM Thread Starter
Thank you for your opinion. I will try putting another battery on it. Any other ideas on why it would have died? I have had issues in the past of the battery being weak and trouble starting but still it shouldn’t have died.
Bobby S is offline
post #4 of 7 (permalink) Old 05-26-2019, 01:11 PM Thread Starter
Update: pulled tank and added fuel into throttle bodies. Still didn’t start. It fired maybe a couple times and that’s it. Anyone got some advice? Also put battery on charger
Bobby S is offline
post #5 of 7 (permalink) Old 05-26-2019, 03:26 PM Thread Starter
Found problem, code 19 on dash found out ignition switch wires where they tuck around the tank all of them are chewed up
ID:	999143   Click image for larger version
Bobby S is offline
post #6 of 7 (permalink) Old 05-30-2019, 02:59 AM Thread Starter
Found these two black wires but do not know where they go. Does anyone know what they go to?
Bobby S is offline
post #7 of 7 (permalink) Old 05-30-2019, 05:08 AM
Aikuken's Avatar
Looks like your steering damper connection.
Sent from my SM-A305F using Tapatalk
Aikuken is offline
‘12 won’t start (again) JimBoTheGent 09-14 R1 Mechanical Help 2 05-07-2019 06:27 PM
08 cranking but won’t start Rparrish916 07-08 R1 Mechanical Help 4 12-11-2018 07:37 AM
06 r1 won’t start Taralynn2021 04-06 R1 Mechanical Help 7 07-09-2018 05:27 PM
Bike won’t start Srn054 07-08 R1 Mechanical Help 6 05-30-2018 04:51 AM
HELP!!! Bike died and won't start! r1ryder1770 Mechanical / Help 26 07-24-2006 10:08 AM
