R1 Died in 1st gear while hot. - Yamaha R1 Forum: YZF-R1 Forums
post #1 of 9 (permalink) Old 06-13-2019, 04:19 PM Thread Starter
TReX2011's Avatar
So I recently got my 2010 R1 running again a month ago and I rode it for a solid week with no issues. It's got new plugs, im gonna change the oil soon.
I was riding today and at a complete stop, with the bike in 1st gear and the clutch pulled in, it completely died. Luckily it started right back up and I made it home.
I tried to replicate the issue in the driveway and sure enough it died in 1st gear, about 220 degrees, and then the battery was too weak to restart the bike.
So now I'm waiting on my wife to get home with the car so I can jump the bike. I thought maybe the clutch cable needed to be tightened up so I adjusted it more tight on the handle-bars but of course before I had the chance to try again the battery is deadzo
I bought a cheap battery off ebay (YTZ10S)? or something of the sort, anyway I think it's 8.6AH and 140 cold cranking amps. I saw other batteries were like 190 cold cranking amps
Do you guys think it's the cheap ebay battery? Anyone else encountered this issue? The clutch was replaced about 1-2K miles ago but I'm wondering if I should replace it again.
Thanks in advance.
REX
TReX2011 is offline
post #2 of 9 (permalink) Old 06-15-2019, 11:09 AM
My R1 is the original 1998 R1.
Hello Rex,
In first gear, or neutral as well ?
Kickstand up or down ?
Fan kicking-in ok at 104-6c ?
Nick
Have fun, and ride defensively !
RINJR is offline
post #3 of 9 (permalink) Old 06-15-2019, 11:16 AM Thread Starter
TReX2011's Avatar
First gear also, with kickstand down. Fans seem to be oeprating properly. Even scair today while driving home it died in 6th gear at lower rpms, I had to pull over and restart the bike.
TReX2011 is offline
post #4 of 9 (permalink) Old 06-15-2019, 11:50 AM
Ok, here's what I would check:
Fuel pump intermittent (on, then maybe off, then on again, etc)
Fuel filter (a big maybe - but I don't readily see it as a culprit)
Fuel tank breather blocked (to let air in to displace the volume of the fuel pumped out).
Fuel tap defective.
I cannot see an issue concerning the battery.
Nick
RINJR is offline
post #5 of 9 (permalink) Old 06-15-2019, 12:19 PM Thread Starter
TReX2011's Avatar
I was honestly thinking the same about the fuel pump. I bought a cheap relay on ebay that does the starter and the fuel pump and I did notice the fuse doesnt fit tightly. I had an issue where it shut off. I'm going to try and replace that first. I replaced the fuel pump assy on the bike not too long ago with one I bought off ebay it came off a wrecked bike with only 12k miles.
TReX2011 is offline
post #6 of 9 (permalink) Old 06-15-2019, 12:28 PM
Cool. Let us all know how you get on ?
RINJR is offline
post #7 of 9 (permalink) Old 06-15-2019, 02:27 PM Thread Starter
TReX2011's Avatar
I'm a little confused, the part iw as talking about was the starter solenoid, it has a fuse in it for the fuel pump also.
Where is the actual fuel pump relay located on this bike, do you know?
again its a 2010
TReX2011 is offline
post #8 of 9 (permalink) Old 06-16-2019, 01:05 AM
I don't where it is on a 2010 but if you search for photo fuel pump relay yamaha yzf r1 2010 you should be able to locate it.
RINJR is offline
post #9 of 9 (permalink) Old 06-20-2019, 01:43 PM
BusterBoo's Avatar
electrical?
Electrical gremlin? Wouldn't wish that on anyone, but I've dealt with a similar issue. Turned out to be wiring problem. Once old wires with poor insulation got hot enough, resistance went way up, charging system stopped working, battery went dead. Doesn't sound like that's what you're dealing with, at least I'll hope it isn't. Little buggers can be difficult to track down.
Oh wait, people are already suggesting something similar.
Last edited by BusterBoo; 06-20-2019 at 01:44 PM. Reason: people already pointed to this potential issue
BusterBoo is offline
09 R1 with bad misfire hickuping while taking off in 1st gear. and while acceler... R1Dtwo 09-14 R1 Mechanical Help 72 05-01-2012 05:21 AM
09 r1 moves while in 1st gear and clutch pressed aniolpl 09-14 R1 Mechanical Help 9 04-29-2012 04:09 PM
1st Post, 1st R1, 1st Crash rlscott23 General Motorcycle Discussions 28 09-10-2006 04:35 PM
Hot, hot, SUPER INSANELY HOT deal! Dramacydle Off Topic Talk 30 11-05-2003 12:31 PM
HOT!HOT!HOT!02R1 SANMAN Appearance & Mods 23 06-24-2002 09:21 AM
