Thinking about buying 2001 R1 - Yamaha R1 Forum: YZF-R1 Forums
  • 1 Post By ChR1z
post #1 of 11 (permalink) Old 05-15-2019, 03:09 PM Thread Starter
My neighbor has an 01 r1 has been sitting for almost a year 19k on the odometer cranks but wont turn over looks like the carbs may be leaking he wants to sell it to me for 1200 and some ceiling fans installed in his house is that a good deal? For an 18yr old r1 not running
Mrwilliamsel is offline
post #2 of 11 (permalink) Old 05-15-2019, 05:05 PM
Hope is what makes us Human.
Benocehcap's Avatar
Last gen of the Carb R1. ALWAYS a good idea! but we need pix! looks pricy!
Not every legend is a myth, some are flesh and blood. Some legends walk among us, but they aren’t born, they’re built. Legends are made from iron & sweat, mind and muscle, blood and vision and victory. Legends are champions, they grow, they win, they conquer.
Benocehcap is offline
post #3 of 11 (permalink) Old 05-15-2019, 05:27 PM Thread Starter
I'll take more when he gets home if I can
ID:	998859   Click image for larger version
post #4 of 11 (permalink) Old 05-15-2019, 07:02 PM Thread Starter
I sent them
post #5 of 11 (permalink) Old 05-16-2019, 06:44 AM
Klaus Von Slowpoke
bsgesch's Avatar
You'd be buying someone else's problem and an older bike with a scarce parts availability and no aftermarket anymore. If that intrigues you (or at least doesn't scare you), have fun. I gave up on carb'ed bikes 15 years ago.
Do you have to leave so soon? I was just about to poison the tea.
bsgesch is offline
post #6 of 11 (permalink) Old 05-25-2019, 06:14 PM
Me personally I could not disagree more - parts for the 98 - 01 are everywhere are dirt cheap. Just about everything swaps accept for the upper and rear fairings, headlights and gas tank - none of which you need. Forks and triple from every year (Can't confirm 2015 and up) can fit in that frame - and that's just the start. I have an 03 motor in an 01 frame (Injected but I'd take the card'd motor back in a heart beat). You can pretty much put anything you want from any year bike on the 01 frame. 98-03 motors more or less bolt up direct, if you want the 02 03 you need the harness, gauges, ecu, sensors etc (A 'kart' kit basically) but why would you? Carbs are easy easy to deal with when there's a problem. The FI can be far more of a pain in the ass - especially if someone put parts on the bike. Once you get through all the standard TB adjustments - sync etc, and when that doesn't clear up the problem - now you have to go and look at sensors and software... Total PIA. IF carbs aren't running right, you pull em' - clean em., sync em (If needed) check to see if it's been jetted - check to see if the vacuum slide are OK - If that all checks out then you are good - if not you sort it out and that's it. Carbs all the way. They fuel based on vacuum - they don't need to be told to fuel based on anything. They simple meter the fuel as per the engine's draw. Simple. The only advantage FI has is it's ability change fueling through software - build a new map instead of fiddling with needle design, height and jet sizes. That is most definitely a big advantage BUT!! trouble shooting carbs is far more easy with less to go wrong.
The 01 is easy as can be to work on.. If the bike was intact and just stopped running b/c it's been sitting I'd do it. I'd tell em $1000 and we're good. The 01 carb model has the best low end grunt of them all and still pulls more than most will ever use on top.
Benocehcap likes this.
Makin' Ponies....
ChR1z is offline
post #7 of 11 (permalink) Old 05-25-2019, 07:06 PM
My R1 go to warp drive
Sabotage's Avatar
I agree, carbs are easier to sort out if there's a problem but carbs have problems more often than FI. I would buy that bike in a heart beat if i was the one repairing it, they are great bikes. I had an 01 that i loved. If i had to send it to a shop then i would pass. Shop prices can go up quickly. Besides the crap start, carbs are just as good as FI to me. I have six bikes. R1 (FI), ZX6R (FI), Road Star (carb), YZ250 (carb), SV650 (carb), Ruckus (carb) and i really do not see any real disadvantage of the carbs beside the crappy start.
PCV tuned, Bazzaz QS, Air box mod, BMC Filter, Block off plates, Flashed ECU, -1 Front Sprocket, SpeedoDRD, Spiegler Lines, EBC Extreme Pro pads, Braking SK Rotors, Q3's, Leo Vince Carbon Fiber slip-on W/ Y-Pipe, Black and Gold Euro conversion, 10,000k HID, Brembo MC and clutch perch, Smoke Puig Windscreen, Shogun Frame Sliders, Signal mirrors, Harris rearset, Techtronic auto blipper, EK 3D 520 chain conversion, Ohlins 30mm ctrg & TTX shock, Lightech chain adjuster, CF sbk hugger, TI bolts kit
Sabotage is offline
post #8 of 11 (permalink) Old 05-26-2019, 08:00 AM
Very good point regarding who would be working on it. Indeed if you can't do the work that may be an issue. However when you say crap start that cracks me up. My 02 R1 is infinitely harder to start than my 01. The autochoke on the 02 sucks and it often has to be cranked 2 or 3 times along with playing with the throttle before it kicks. If it had a manual choke this wouldn't happen. I can see how It can be converted to a manual and I think I may just do that. I understand this got better with the 04s but in my opinion, I don't want anything thinking for me - No my choke, not my Windows OS and not even my wife. Well maybe the wife here are there.
Makin' Ponies....
ChR1z is offline
post #9 of 11 (permalink) Old 05-26-2019, 09:58 AM
Sabotage's Avatar
Come on bro, a properly working FI system, you turn the key you press start and the thing start and you're good no matter what. When the auto fuel enrichment is done doing its thing, you're about ready to go. Carbs, you have to mess with how much choke to give it if any, how long to leave the choke on for, blip the throttle a few time to make sure the fuel is flowing properly and it won't cut off. With all that, you still have to adjust this procedure depending on the weather. People with carb bikes, the procedure becomes so natural that they dont even realize how crappy the starting procedure is. Get a properly working FI, you're like what have i been doing with my life... Dont let a carb bike sit for some time and try to start it. What a PITA to get it started. I've learned to just spray starter fluid into the intake and hope the jets are still clear. A FI, no freaking problem in any condition or situation, if it aint broken it'll start...
Sabotage is offline
post #10 of 11 (permalink) Old 05-26-2019, 05:54 PM
i would not go back to carburated engines, waste of time really, i'm not that nostalgic
Fuel injection for the win, tuning on the fly is the shit#@$%!
post #11 of 11 (permalink) Old 05-27-2019, 07:09 PM
Yeah let an FI system sit and see what happens. Carbs definitely do not have problems more often than FI - they've been around much longer. You've just been lucky. I talk to people who never lived through carb'd bikes - know nothing about carbs and they complain about them - yet these same people can't fix FI either.. SO where does that opinion come from. Only what they know. And when that auto choke which is the same system as a manual - just controlled by water temp which pushes the choke automatically and can fail just with low coolant level - goes south how can you start the bike? Its all nice and great until it ain't. Then you'll wish you had that manual choke. Choke has NOTHING to do with fuel flow at all. And if the bike is running right - you should only need it for about 10 seconds and then its off and go - the rest of your description of choke operation is either wrong by you or the bike is fubar. I've worked on both extensively - EXTENSIVELY. When it comes to choke I take a manual any and every day.
Makin' Ponies....
ChR1z is offline
Who's thinking of buying the 04 r1? ricardo General Motorcycle Discussions 66 07-30-2003 09:42 PM
Thinking about buying a 2003 R1 jszydlo General Motorcycle Discussions 9 07-15-2003 12:20 PM
thinking buying selling R6 for R1 gsxrawd General Motorcycle Discussions 8 06-08-2003 05:23 PM
So who here is thinking about buying/trading for the 2003 R1? BlueR1 General Motorcycle Discussions 36 09-10-2002 08:50 PM
thinking about buying an 02 r1 ghostryder General Motorcycle Discussions 2 07-21-2002 06:01 PM
