20-03 R1 Auto tune sensor install? - Yamaha R1 Forum: YZF-R1 Forums
02-03 Performance Group Post your R1 performance bike builds for 02-03 model years
post #1 of 4 (permalink) Old 05-20-2019, 04:01 PM Thread Starter
Need more Boost
I was told to install on #1 cyclinder 8" down from Port. Problem I am having is there is no room. Trying to figure out how well it will be after pipes come together after the exhaust valves
Thanks Joe
hereismylife is offline
post #2 of 4 (permalink) Old 05-20-2019, 04:13 PM
uhm.. most of us run an AT bosch sensor at the 'midpipe' where all 4 collectors eventually end up.
this is just a random example of yer typical y-pipe showing proper 02 sensor location / angle, etc.
at least its an easy way to get a tune for all 4 cylinders.. the AT units only come in 'single' o2 sensor and DUAL o2 sensor..
are you planning on tuning all 4 cylinders separately? i would not bother.
bacchus40 is online now
post #3 of 4 (permalink) Old 05-20-2019, 09:03 PM Thread Starter
Need more Boost
I still have the stock exhaust. All four go right into the exup then under the engine short pipe then to the slip on pipe. I was looking and think I found a spot right after the exup under the engine. I have the at-200. 1 sensor.
post #4 of 4 (permalink) Old 05-20-2019, 10:05 PM
thats what i figured. the at-200 is the most common.
Bazzaz Auto tune (Z-AFM) with Flash Tune Pyro Kahn 09-14 R1 Mechanical Help 2 05-09-2014 12:20 PM
Bazzaz Auto-Tune vs Power Commander V w/ Auto Tune????? brandon821 Appearance & Mods 43 08-17-2013 03:11 PM
09-11 R1 Need help installing Auto Tune AT200 o2 sensor plug marider 09-14 R1 Mechanical Help 5 03-02-2013 05:45 AM
picture {asap please} request, AUTO TUNE O2 SENSOR / LEO VINCE Y-PIPE INSTALL!?? bacchus40 09-14 R1 Mechanical Help 0 06-21-2011 01:18 PM
Auto tune Vs. Dyno tune? (all bikes) fivespotshooter General Motorcycle Discussions 4 11-25-2010 08:19 PM
