Pcv install - Yamaha R1 Forum: YZF-R1 Forums
post #1 of 9 (permalink) Old 09-24-2015, 04:26 PM Thread Starter
PrimoCyp25's Avatar
Pcv install
I'm in a process of installing pcv with autotune and pod300 but can't find a speed sensor wire, older r1 it was a pink one on 3 prong plug, anyone knows where I can locate one on 15 model?
PrimoCyp25 is offline
post #2 of 9 (permalink) Old 09-24-2015, 06:50 PM
Greenfield, MN(55357)
JLeosnow's Avatar
JLeosnow is offline
post #3 of 9 (permalink) Old 09-25-2015, 12:34 AM
notorious's Avatar
Speed sensor or TPS? I didnt saw speed sensor in the manual.do i missed something?
notorious is offline
post #4 of 9 (permalink) Old 09-25-2015, 04:01 AM Thread Starter
PrimoCyp25's Avatar
It's optional, I sent dynojet an email, waiting for reply
I know you can also hook up a temp sensor and get that calibrated, and map-menafold absolute pressure that can help with tuning your bike as well, but can't find wiring diagram for new r1,
post #5 of 9 (permalink) Old 09-25-2015, 11:39 AM
notorious's Avatar
good to know... thanx!
post #6 of 9 (permalink) Old 09-25-2015, 12:14 PM Thread Starter
PrimoCyp25's Avatar
Just talked with dynojet and they can't get the signal from speed sensor that's why they went with gear position sensor, crank and gray wire to pin11 white wire is throttle position, so far that's all we can hook up the pcv
post #7 of 9 (permalink) Old 09-26-2015, 03:08 PM Thread Starter
PrimoCyp25's Avatar
Does anybody if gear advanced option can be calibrated without speed sensor wire?
post #8 of 9 (permalink) Old 05-20-2019, 12:47 PM
The B Lab's Avatar
Is this thread dead, or has there been an update if the speed sensor signal (presumably rear wheel, where it enters the ABS unit) is actually required? Auto Tune altering AFR per gear is pretty interesting!
The B Lab is offline
post #9 of 9 (permalink) Old 05-20-2019, 01:39 PM
holly old thread batman.. 2015?
to answer the question above.. advanced gear tuning can only be done with speed sensor wired in.
you need to calibrate gear position based on speed/ rpm so yeah.. youre sol without it
