Longer brake reservoir hose - Yamaha R1 Forum: YZF-R1 Forums
post #1 of 5 (permalink) Old 05-27-2019, 11:24 PM Thread Starter
After installing clipons the hose from the front brake master reservoir to cylinder is too short.
Does anyone know what the inner and outer diameter of the hose is and what are people using as a replacement?
Tonybeau is offline
post #2 of 5 (permalink) Old 05-28-2019, 03:03 AM
Jimmy boy's Avatar
When I installed my RCS master I also bought a brembo bracket bracket kit that came with a clear hose.
Jimmy boy is offline
post #3 of 5 (permalink) Old 05-28-2019, 04:32 AM
jrcidr6's Avatar
Most use Tygon hose . And 6mm for brembo Mc and 8mm for stock.
Tygon 2375 Clear Brake Fluid Reservoir Hose 5/16" 8mm ID 1 Foot https://www.amazon.com/dp/B0117SUXLO..._UWr7Cb6V67A69
jrcidr6 is offline
post #4 of 5 (permalink) Old 05-28-2019, 07:21 PM
If you want black, anything made of EPDM rubber will do. I used coolant reservoir hose, cost about $2 for a ft. Or you can use fuel hose if you want reinforced.
NZ_R1 is offline
post #5 of 5 (permalink) Old 05-28-2019, 08:38 PM Thread Starter
Thanks for the replies. I picked up some Tygon 2375 from McMaster-Carr.
Tonybeau is offline
Brake reservoir to MC hose diameter? mattf Mechanical / Help 5 05-01-2010 07:23 AM
Early gen R1 rear brake master cyl - reservoir hose SHEPPO Mechanical / Help 0 04-06-2010 03:32 AM
FYI: brake fluid reservoir hose corwyn Mechanical / Help 1 09-23-2005 10:40 PM
Front Brake Master Cylinder to Reservoir Hose? Mark618 Mechanical / Help 3 06-13-2004 07:45 AM
Brake hose from reservoir meretrix Mechanical / Help 8 01-24-2004 09:03 PM
