2015 R1/M Transmission Recall - Page 118 - Yamaha R1 Forum: YZF-R1 Forums
2015+ Yamaha R1M Recalls Only manufacturer issued recalls and service bulletins belong in this section
 1238Likes
post #2341 of 2344 (permalink) Old 03-06-2019, 12:01 AM
Originally Posted by andrewstclair View Post
yea the rod pins are 90 degrees to each other so the weights don't line up the same and it requires custom counter weights to be made and adjusted
Yes - There is some interesting stuff on the internet about balancing a IL4 crossplane, which i didn't know about until I did an in-depth search last week - I previously was into balancing & modifying Honda IL4 (car) engines. I was surprised at how different a IL4 CP is in terms of balancing - and with the overall weight reduction of th 2015+ R1 (thinner lighter crank cases) the margin for "errors" is small - one REALLY needs to know what you are doing (and IMHO have access to some really expensive engineering resources)
bacchus40 likes this.
2391jessie is offline
post #2342 of 2344 (permalink) Old 03-06-2019, 07:58 PM
makes sense.. been meaning to read up on this voodoo science
post #2343 of 2344 (permalink) Old 03-06-2019, 10:03 PM
andrewstclair's Avatar
Some crankshafts you balance just the crank itself and then match weights on the rods n pistons. Some you have to balance factoring in weights of pistons n rods. Some you have to make actual weights and bolt them in place of the rods and spin it up but it varies between what engine builder you use, some have a different calculation of what the weights should be. There's equations they use to factor how much of the pistons and rods need to be balances out on the crank and how much is like free weight? It's alot of info and I don't think I could learn it all unless it was something I went into and was doing it everyday with someone teaching me. I just know enough to know when they guy I'm talking to shouldn't be touching my engines.
09 R1 black/gold SOLD
2015 R1M 007
2016 R1 Track
andrewstclair is offline
post #2344 of 2344 (permalink) Old 03-07-2019, 12:35 PM
An R1 kinda day!
Buttafewcoe's Avatar
ride slow? On occasion I guess. I got a couple YouTube vids that say otherwise. But I'm not bouncing it off the rev limiter either.
"Learn all you can today. Tomorrow you may need to know it!" ...(Buttafewcoe)
Buttafewcoe is offline
