Yamaha R1 Forum: YZF-R1 Forums (https://www.r1-forum.com/forums/)
-   09-14 R1 Mechanical Help (https://www.r1-forum.com/forums/161-09-14-r1-mechanical-help/)
-   -   Does anyone know what this part is? (https://www.r1-forum.com/forums/161-09-14-r1-mechanical-help/629959-does-anyone-know-what-part.html)
jgreen 05-20-2019 08:48 AM
1 Attachment(s)
This part came off my '13 R1. I believe it goes under the tank and holds two hoses but I can't find it on any of the parts fiche. Anyone have a part number?
Thanks
Jason
iamzombie 05-20-2019 10:22 AM
Pretty sure that holds the ends of the fuel overflow hoses, if it's anything like my 07 was.
Aikuken 05-20-2019 11:22 AM
It holds the radiator overflow hose (100% sure of this) and another item (one of the thermostat bypass hoses, or stator coil wire) together. Hope this helps in finding the part no.
Sent from my SM-A305F using Tapatalk
jgreen 05-20-2019 12:55 PM
Thanks guys. That helps for sure.
Jacobien 05-23-2019 12:09 AM
That looks like the fuel line holder, that attaches to the bottom of the tank.
Aikuken 05-23-2019 05:47 AM
Holds radiator overflow to crank vent.
Fuel line doesn't have a clip. Overflow and vent from tank have. Picture of that is also attached. https://uploads.tapatalk-cdn.com/201...1b72958545.jpghttps://uploads.tapatalk-cdn.com/201...8871733691.jpg
jgreen 05-23-2019 06:07 AM
Thanks @Aikuken . That's the piece!
ChR1z 05-23-2019 09:54 AM
Nice.. Aikuken I think you and I have the same thing going on accept I have my own person 98 99 00 01 02 03 salvage yard going on and you have the subsequent years -=- I'm guessing 04 - 08? :D
Aikuken 05-23-2019 10:07 AM
09-14. But you're spot on with the description. It's a salvage yard in my garage.
ChR1z 05-23-2019 10:17 AM
2 Attachment(s)
Nice - I'm looking to build me an 09 - 14 for a cheap as possible.. Where are you at anyway?
Been looking for a salvage bike to start with... Every time I have enough cash to pick one up life comes along and eats the money.
This is my 2001 - its got more mods than god. The only thing left that's actually year and model correct and un-modded is rear wheel, frame and rear seat. Its got the 03 FI motor and a buncha buncha other stuff... The front end from triple to caliper should look familiar. The 2nd pic is the old paint job but you can see the modified front end - All the plastics and the tank and custom. The are all fabricated in some way and the front is actually an 01 and an 08 front fairing cut and welded together so I could use the 08 head lights. I had to weld up a custom fairing stay too but it wasn't bad. The biggest pain in the ass has been the fueling. I had to go from low pressure carb'd to high pressure FI. I started off with an external in-line pump and it worked but space was tight and lines could get pinched easily. This winter I cut the bottom of an 03 tank out and welded it in my 01 tank so I could install the sending unit from a in-tank high pressure deal. I used an 07 R6 - slightly modified for a return line. I've been cleaning that system up as of late and its finally pretty much done. Getting it all to work with no leaks and no kinks all while allow the tank to be raised to maintenance was a serious PIA but I'm finally there. The thing rides like a dream.
Sorry OP - Did not mean to highjack your threadio...
It does sound like the ETV fuse or bad electronic on the TBs. You can get them pretty cheap on eBay.
Aikuken 05-23-2019 11:38 AM
I'll send you a pm
Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
