I believe a shorter dogbone will raise the height.
Stock is off my 00, other is a copy of the Graves link. Should probably have this moved to the 00-01 Performance threads.
Excellent, that’s what I’m after. Thanks heaps for that. Your Graves linkage is nice. Creating, let alone moving a thread was hard enough mate.
The Graves linkage raises the rear then?Stock is off my 00, other is a copy of the Graves link. Should probably have this moved to the 00-01 Performance threads.
Yeah shorter dogbone raises height, longer lowers it.The Graves linkage raises the rear then?
Sent from my SM-S906E using Tapatalk
A local shop made a few several years ago using an original link for measurements. I have an original link as well, looks the same. I believe Graves made a few versions of these, if you do a search somewhere here there’s a thread where he talks about them.Did you have the linkage made, or are they available to buy? I understand that Graves has not made them for a long time.
