Key off
Hold down sellect button while turning key on.
Then follow below directions and go thru all functions.
INSTRUMENT AND CONTROL FUNCTIONS
3
Display brightness and engine
speed indicator light control mode
This mode cycles through five control
functions, allowing you to make the fol-
lowing settings in the order listed be-
low.
1. Display brightness: This function
allows you to adjust the brightness
of the multi- function display to suit
the outside lighting conditions.
2. Engine speed indicator light activi-
ty: This function allows you to
choose whether or not the indica-
tor light should be activated and
whether it should blink or stay on
when activated.
3. Engine speed indicator light acti-
vation: This function allows you to
select the engine speed at which
the indicator light will be activated.
4. Engine speed indicator light deac-
tivation: This function allows you
to select the engine speed at
which the indicator light will be de-
activated.
5. Engine speed indicator light
brightness: This function allows
you to adjust the brightness of the
indicator light to suit your prefer-
ence.
NOTE: _
�œTo make any settings in this mode,
you have to cycle through all of its
functions. However, if the key is
turned to �gOFF �h or the engine is
started before completing the pro-
cedure, only the settings made be-
fore the �gSELECT �hbutton was last
pushed will be applied.
�œIn this mode, the multi- function
display shows the current setting
for each function ( except the en-
gine speed indicator light activity
function) ._
1. Engine speed indicator light
2. �gSELECT �h button
3. �gRESET �h button
