1 - 2 of 2 Posts
Hi, I am having trouble removing the rotor to replace a burnt out stator. I have been able to block off the rotor with a holding tool am using a bolt identical in spec to the rotor removal “tool” available. The rotor will not pull off in spite of huge force placed on the bolt. I am following procedure as in Haynes manual and on YouTube vids. Am I missing something? I am open to any advice and education. Thanks in advance.
I'm not an expert experienced mechanic and have not personally had this situation but I have heard of these things getting so hot when they go bad that they can fuse together--may literally need to apply heat to remove and replace both, or again so I've heard. It sucks I know!
1 - 2 of 2 Posts
