That is fine.Xorn said:Just curious what temp my bike should be. I noticed yesterday in traffice it was running at 221 degrees. Once I started moving again it dropped to 167ish. I suppose its normal my 221 seems high.
:fork
Modded bikes go even higher...02R1guy said:02-03 r1's got that high in traffic
Your fine
The motor on the FJR is larger, and runs slightly warmer than the R1's. However, the R1's second? fan comes on before the FJR's. This seems to me a liitle off, but thanks to input like yours then makes me realize I probably don't need to sweat other simple things like oil changes or checking the brake fluid as much, also.02R1guy said:just too many newbies to the 04 are sweating over simple stuff.
